inputText
), select values (such as inputNumber
, inputRange
, inputColor
, inputDate
, and select
components), edit text (such as richTextEditor
), and load files (such as inputFile
).This chapter includes the following sections:
If you want to use an input component that selects from a list of items that may be potentially large, or may represent relationships between objects (such as creating a list to represent an attribute that is a foreign key to another object), then you may want to use a list of values component. For information about those components, see Using List-of-Values Components.
The ADF input components is a means by which input data can be submitted to the application. You can use various input components in your forms that provides built-in functions to collect input data from the users, such as creating a new file, adding a rich text editor to the form, or providing a multiple choice list.
Input components accept user input in a variety of formats. The most common formats are text, numbers, date, and selection lists that appear inside a form and are submitted when the form is submitted. The entered values or selections may be validated and converted before they are processed further. Figure 11-1 shows ADF Faces standard input components.
ADF Faces input components also include a number of components that allow users to select one or multiple values, as shown in Figure 11-2.
Input components are often used to build forms for user input. For example, the File Explorer application contains a form that allows users to create a new file. As shown in Figure 11-3, input components allow users to enter the name, the size, select permissions, and add keywords, and a description for a file. The Name field is required, as noted by the asterisk. If a user fails to enter a value, an error message is displayed. That validation and associated error message may be configured on the component (by setting the required
or requiredMessageDetail
attribute), or handled on the server (by setting the showRequired
attribute).
Figure 11-3 Form Uses Input Components
The richTextEditor
component provides rich text input that can span many lines and can be formatted using different fonts, sizes, justification, and other editing features that may be required when you want users to enter more than simple text. For example, the richTextEditor
might be used in a web-based discussion forum, allowing users to format the text that they need to publish, as shown in Figure 11-4.
Figure 11-4 richTextEditor Used in a Discussion Forum
The inputFile
component allows users to browse for a local file to upload to the application server. For example, an email message might allow users to attach a file to a message, as shown in Figure 11-5.
The ADF Faces selection components allows users to make selections from a list of items instead of typing in values. ADF Faces provides both single choice selection lists and multi-choice selection lists. Single-choice lists are used to select one value from a list, such as the desired drink in an online food order, as shown in Figure 11-6.
Figure 11-6 Users Can Select One Value From the selectOneChoice Component
ADF single-selection components include a dropdown list (as shown in Figure 11-6), a list box, radio buttons, and checkboxes.
ADF multi-selection components allow users to select more than one value in a list. For example, instead of being able to select just one drink type, the selectManyChoice
component allows a user to select more than one drink, as shown in Figure 11-7.
Figure 11-7 Users Can Select Multiple Values From the selectManyChoice Component
ADF multiple choice components include a dropdown list, checkboxes, a checkbox list, a shuttle, and an ordered shuttle.
Best Practice:
You can use either selection lists or list-of-values (LOV) components to display a list. LOV components should be used when the selection list is large. LOV components are model-driven using the ListOfValueModel
class and may be configured programmatically using the API. They present their selection list inside a popup window that may also include a query panel. Selection lists simply display a static list of values. LOV components are single select and allow you to select only one option, hence should not be used for multiple selections. For information about using LOV components, see Using List-of-Values Components.
The form components provide a container for other components. The form
component represents a region where values from embedded input components can be submitted. Only one form component per page is supported. ADF Faces also provides the subform
component, which adds flexibility by defining subregions whose component values can be submitted separately within a form.
If you are using an input component that is configured to display a list of suggestions with the af:autoSuggestBehavior
tag and uses AdfCustomEvent
to send custom event to the server, the server listener will not be executed as af:autoSuggestBehavior
tag interrupts the input value life cycle after Apply request value phase and jumps to render response phase.
You may find it helpful to understand other ADF Faces features before you implement your input components. Additionally, once you have added an input component or form to your page, you may find that you need to add functionality such as validation and accessibility. Following are links to other functionality that input components can use.
Using parameters in text: You can use the ADF Faces EL format tags if you want text displayed in a component to contain parameters that will resolve at runtime. See How to Use the EL Format Tags.
Client components: Input components can be client components. To work with the components on the client, see Using ADF Faces Client-Side Architecture .
JavaScript APIs: All input components have JavaScript client APIs that you can use to set or get property values. See theJavaScript API Reference for Oracle ADF Faces.
Events: Input components fire both server-side and client-side events that you can have your application react to by executing some logic. See Handling Events.
You can add validation and conversion to input components. See Validating and Converting Input.
You can display tips and messages, as well as associate online help with input components. See Displaying Tips, Messages, and Help.
There may be times when you want the certain input components to be validated before other components on the page. See Using the Immediate Attribute.
You may want other components on the page to update based on selections you make from a selection component. See Using the Optimized Lifecycle.
You may want to use the scrollComponentIntoViewBehavior
tag with the richTextEditor component to allow users to jump to specific areas in the component. See How to Use the scrollComponentIntoViewBehavior Tag.
You can change the icons used for required and changed notifications using skins. See Customizing the Appearance Using Styles and Skins.
You can make your input components accessible. See Developing Accessible ADF Faces Pages.
Instead of entering values for attributes that take strings as values, you can use property files. These files allow you to manage translation of these strings. See Internationalizing and Localizing Pages.
If your application uses ADF Model, then you can create automatically bound forms using data controls (whether based on ADF Business Components or other business services). See Creating a Basic Databound Page in Developing Fusion Web Applications with Oracle Application Development Framework.
The ADF shuttle component that you add to a page lets users make a single selection or multiple selections from an available list of values box and add them to a selected list of values box.
A form is a component that serves as a container for other components. When a submit action occurs within the form, any modified input values are submitted. For example, you can create an input form that consists of input and selection components, and a submit command button, all enclosed within a form. When the user enters values into the various input fields and clicks the Submit button, those new input values will be sent for processing.
By default, when you create a JSF page in JDeveloper, it automatically inserts a form
component into the page. When you add components to the page, they will be inserted inside the form
component.
Tip:
If you do not already have an af:form
tag on the page, and you drag and drop an ADF Faces component onto the page, JDeveloper will prompt you to enclose the component within a form component.
The following example shows two input components and a Submit button that when clicked will submit both input values for processing.
<af:form id="f1"> <af:panelFormLayout id="pfl1"> <af:inputText value="#{myBean.firstName}" label="#{FirstName}" id="it1"> </af:inputText> <af:inputText value="#{myBean.lastName}" label="#{LastName}" id="it2"> </af:inputText> <af:button text="Submit" id="b1"/> </af:panelFormLayout> </af:form>
Because there can be only one form
component on a page, you can use subforms within a form to create separate regions whose input values can be submitted. Within a region, the values in the subform will be validated and processed only if a component inside the subform caused the values to be submitted. You can also nest a subform within another subform to create nested regions whose values can be submitted. For information about subforms, see Using Subforms to Create Sections on a Page.
The following example shows a form with two subforms, each containing its own input components and buttons, such as the Submit button. When a Submit button is clicked, only the input values within that subform will be submitted for processing.
<af:form id="f1"> <af:subform id="s1"> <af:panelFormLayout id="pfl1"> <af:inputText value="#{myBean.firstName}" label="#{FirstName}" id="it1"> </af:inputText> <af:inputText value="#{myBean.lastName}" label="#{LastName}" id="it2"> </af:inputText> <af:button text="Submit" id="b1"/> </af:panelFormLayout> </af:subform> <af:subform id="s2"> <af:panelFormLayout id="pfl2"> <af:inputText value="#{myBean.primaryPhone}" label="#{PrimaryPhone}" id="it3"> </af:inputText> <af:inputText value="#{myBean.cellPhone}" label="#{CellPhone}" id="it4"> </af:inputText> <af:button text="Submit" id="b2"/> </af:panelFormLayout> </af:subform> </af:form>
Aside from the basic button, you can add any other command component within a form and have it operate on any field within the form.
In most cases, JDeveloper will add the form component for you. However, there may be cases where you must manually add a form, or configure the form with certain attribute values.
Before you begin:
It may be helpful to have an understanding of form components. See Defining Forms.
You may also find it helpful to understand functionality that can be added using other ADF Faces features. See Additional Functionality for Input Components and Forms.
To add a form to a page:
You should add subform components within a form component when you need a section of the page to be capable of independently submitting values.
Before you begin:
It may be helpful to have an understanding of forms and subforms. See Defining Forms.
You must add a form component to the page. For procedures, see How to Add a Form to a Page.
To add subforms to a page:
You add the button component and configure it using af:resetListener
to reset other input components to their default values. The reset button will act upon only those components within that form or subform.
Before you begin:
To add a button with resetListener to the page:
The ADF inputText component is a textual input field. You can allow users to submit textual input data using these components. You can allow users to enter a single row input text or multiple rows of input text.
Although input components include many variations, such as pickers, sliders, and a spinbox, the inputText
component is the basic input component for entering values. You can define an inputText
component as a single-row input field or as a text area by setting the rows
attribute to more than 1. However, if you want user to enter rich text, consider using the richTextEditor
component as described in Using the richTextEditor Component.
You can allow auto-completion for an inputText
component using the autoComplete
attribute. When set to true
, the component remembers previous entries, and then displays those entries when the user types in values that begin to match those entries.
You can hide the input values from being displayed, such as for passwords, by setting the secret
attribute to true
. Like other ADF Faces components, the inputText
component supports label, text, and messages. When you want this component to be displayed without a label, you set the simple
attribute to true
. Figure 11-8 shows a single-row inputText
component.
Figure 11-8 Single-Row inputText Component
You can make the inputText
component display more than one row of text using the rows
attribute. If you set the rows
attribute to be greater than one, and you set the simple
attribute to true, then the inputText
component can be configured to stretch to fit its container using the dimensionsFrom
attribute. For information about how components stretch, see Geometry Management and Component Stretching. Figure 11-10 shows a multi-row inputText
component.
You can add multiple inputText
components to create an input form. Figure 11-9 shows an input form using two inputText
components.
Figure 11-9 Form Created by inputText Components
You can also configure an insertTextBehavior
tag that works with command components to insert given text into an inputText
component. The text to be entered can be a simple string, or it can be the value of another component, for example the selected list item in a selectOneChoice
component. For example, Figure 11-10 shows an inputText
component with some text already entered by a user.
Figure 11-10 inputText Component with Entered Text
The user can then select additional text from a dropdown list, click the command button, and that text appears in the inputText
component as shown in Figure 11-11.
Figure 11-11 inputText Component with Inserted Text
You can use an inputText
component inside any of the layout components described in Organizing Content on Web Pages.
Before you begin:
It may be helpful to have an understanding of how the attributes can affect functionality. See Using the inputText Component.
To add an inputText component:
The insertTextBehavior
tag works with command components to insert given text into an inputText
component. To allow text to be inserted into an inputText
component, add the insertTextBehavior
tag as a child to a command component that will be used to insert the text.
tag cancels server-side event delivery automatically; actionListener
or action
attributes on the parent command component will be ignored. If you need to also trigger server-side functionality, you must add an custom client listener to deliver the server-side event. See Sending Custom Events from the Client to the Server.
Before you begin:
Before you add an insertTextBehavior
tag, you need to create an inputText
component as described in How to Add an inputText Component. Set the clientComponent
attribute to true
To add text insert behavior:
An ADF input number component is a numerical input field. You can allow users to submit numerical input data using these components. Some of the number components are inputNumberSlider in Horizontal and Vertical layout, inputRangeSlider, and inputNumberSpinbox components.
The slider components present the user with a slider with one or two markers whose position on the slider corresponds to a value. The slider values are displayed and include a minus icon at one end and a plus icon at the other. The user selects the marker and moves it along the slider to select a value. The inputNumberSlider
component has one marker and allows the user to select one value from the slider, as shown in Figure 11-12 in horizontal layout, and in Figure 11-13 in vertical layout.
Figure 11-12 inputNumberSlider in Horizontal Layout
Figure 11-13 InputNumberSlider in Vertical Layout
The inputRangeSlider
component has two markers and allows the user to pick the end points of a range, as shown in Figure 11-14.
Figure 11-14 inputRangeSlider in horizontal layout
You can also configure the inputNumberSlider
and inputRangeSlider
components to add a play/pause button that animates the slider across the component's increment values, as shown in Figure 11-15.
Figure 11-15 inputRangeSlider with Play/Pause Button
The inputNumberSpinbox
is an input component that presents the user with an input field for numerical values and a set of up- and down-arrow keys to increment or decrement the current value in the input field, as shown in Figure 11-16.
Figure 11-16 inputNumberSpinbox
When you add an inputNumberSlider
or an inputRangeSlider
component, you can determine the range of numbers shown and the increment of the displayed numbers.
Before you begin:
It may be helpful to have an understanding of how the attributes can affect functionality. See Using the Input Number Components.
To add an inputNumberSlider or inputRangeSlider component:
component allows the user to scroll through a set of numbers to select a value.
Before you begin:
To add an inputNumberSpinbox component:
Using the ADF inputColor and inputDate component you can add a color pallet and a popup calendar in your form.
The inputColor
component allows users to pick a color from a a palette. It presents a text input field for entering code for colors. It also displays a button for picking colors from a palette in a popup, as shown in Figure 11-17.
Figure 11-17 inputColor Component with Popup chooseColor Component
By default, the content delivery for the popup is lazy. When the user clicks the button, the inputColor
component receives a PPR request, and rerenders, displaying a chooseColor
component in a popup
component.
Performance Tip:
If the clientComponent
attribute on the inputColor
component is set to true
, then the popup and chooseColor
component are delivered immediately. If the color palette is large, this could negatively affect initial page load performance.
The default color code format is the hexadecimal color format. However, you can override the format using a ColorConverter
class.
The inputDate
component presents a text input field for entering dates and a button for picking dates from a popup calendar, as shown in Figure 11-18. The default date format is the short date format appropriate for the current locale. For example, the default format in American English (ENU) is mm/dd/yy
. However, you can override the format using a date-time converter (for information about using converters, see Adding Conversion).
Figure 11-18 inputDate Component
When you add a date-time converter and configure it to show both the date and the time, the date picker is displayed as a modal dialog with additional controls for the user to enter a time. Additionally, if the converter is configured to show a time zone, a time zone dropdown list is shown in the dialog, as shown in Figure 11-19.
Figure 11-19 Modal Dialog When Date-Time Converter Is Used
The inputColor
component allows users either to enter a value in an input text field, or to select a color from a color chooser.
Before you begin:
It may be helpful to have an understanding of how the attributes can affect functionality. See Using Color and Date Choosers.
To add an inputColor component:
The inputDate
component allows the user to either enter or select a date.
Before you begin:
To add an inputDate component:
By default, the inputDate
component displays a drop down list of time zones if the associated converter is configured to do so, for example, if you include the time zone placeholder z
in the converter's pattern. The user can only modify the time zone using this list. The list is configured to display the most common time zones.
However, there may be times when you need to display the list of time zones outside of the inputDate
component. For example, on a Application Preferences page, you may want to use a selectOneChoice
component that allows the user to select the time zone that will be used to display all inputDates
in the application. A backing bean would handle the conversion between the time zone ID and the java.util.TimeZone object
. Converters for the inputDate
instances in the application would then bind the time zone to that time zone object.
You can access this list using either an API on the DateTimeUtils
class, or using an EL expression on a component.
Following are the methods on DateTimeUtils
class:
getCommonTimeZoneSelectItems ()
: Returns a list of commonly used time zones.
getCommonTimeZoneSelectItems (String timeZoneId)
: Returns a list of commonly used time zones, including the given time zone if it is not part of the list.
To access this list using EL, use one of the following expressions:
af:getCommonTimeZoneSelectItems
For example:
<f:selectItems value="#{af:getCommonTimeZoneSelectItems()}" id="tzones2" />
af:getMergedTimeZoneSelectItems (id)
For example:
<f:selectItems value="#{af:getMergedTimeZoneSelectItems(demoInput.preferredTimeZoneId)}" id="tzones" />
If you will be using an inputDate
component and a selection list for its time zone on the same page, you must clear out the local value for the inputDate
's time zone to ensure that the value binding for the selection takes precedence. Otherwise, a non-null local value will take precedence, and the inputDate
component will not appear to be updated.In the following example, the backing bean has a reference using the binding attribute to the inputDate
component. When the user picks a new time zone, the ID is set and the code gets the converter for the inputDate
and clears out its time zone. When the page is rendered, since the local value for the converter's time zone is null, it will evaluate #{demoInput.preferredTimeZone}
and obtain the updated time zone.
<af:selectOneChoice label="Select a new timezone" id="soc1" value="#{demoInput.preferredTimeZoneId}" autoSubmit="true"> <f:selectItems value="#{af:getMergedTimeZoneSelectItems(demoInput.preferredTimeZoneId)}" id="tzones" /> </af:selectOneChoice> <af:inputDate label="First inputDate with timezone bound" id="bound1" partialTriggers="tzpick" binding="#{demoInput.boundDate1}"> <af:convertDateTime type="both" timeStyle="full" timeZone="#{demoInput.preferredTimeZone}"/> </af:inputDate> DemoInputBean.java public void setPreferredTimeZoneId(String _preferredTimeZoneId) { TimeZone tz = TimeZone.getTimeZone(_preferredTimeZoneId); setPreferredTimeZone (tz); this._preferredTimeZoneId = _preferredTimeZoneId; } public void setPreferredTimeZone(TimeZone _preferredTimeZone) { this._preferredTimeZone = _preferredTimeZone; DateTimeConverter conv1 = (DateTimeConverter) _boundDate1.getConverter(); conv1.setTimeZone(null); }
The inputDate
component can be configured to show a custom list of time zones using the Time Zone List attribute.
In the following example, the inputDate
component uses the custom time zone list defined by the testInput
backing bean to show only three US time zones.
<af:inputDate id="idtzl" label="InputDate with timezoneList set" timeZoneList="#{testInput.timezoneList}"> <af:convertDateTime type="both" timeStyle="full" timeZone="#{testInput.timezone}/> </af:inputDate> testInput.java public void setTimezoneList(List<String> _timezoneList) { this._timezoneList = _timezoneList; } public List<String> getTimezoneList() { return _timezoneList; } private List<String> _timezoneList = new ArrayList<String> (Arrays.asList("America/Los_Angeles", "America/Denver", "America/New_York"));
Figure 11-21 illustrates the custom time zone list in the inputDate
component defined by the backing bean.
Figure 11-21 Custom Time Zone List in inputDate Component
You can also use the getCustomTimeZoneSelectItems
helper EL method to get custom time zones as a list of SelectItems
, which can then be used with components like selectOneChoice
, as shown in the following example.
<af:selectOneChoice label="Select a timezone" id="soctzlel" value="America/New_York"> <f:selectItems value="#{af:getCustomTimeZoneSelectItems('America/New_York', testInput.timezoneList)}" id="tzonesel" /> </af:selectOneChoice>
Figure 11-22 illustrates the custom time zone list in the selectOneChoice
component defined by the getCustomTimeZoneSelectItems
method.
Figure 11-22 Custom Time Zone List in selectOneChoice Component
The getCustomTimeZoneSelectItems
helper EL method assumes that the input parameter list is sorted by timezone offset. For more information about getCustomTimeZoneSelectItems
method, see the ADF Faces API documentation.
You can allow users to select single or multiple input values by adding ADF selection components in the form. Some of the different selection components are selectBooleanCheckbox, selectBooleanRadio, selectManyCheckbox and so on.
The selection components allow the user to select single and multiple values from a list or group of items. ADF Faces provides a number of different selection components, ranging from simple boolean radio buttons to list boxes that allow the user to select multiple items. The list of items within a selection component is made up of a number of selectItem
components
All the selection components except the selectItem
component delivers the ValueChangeEvent
and AttributeChangeEvent
events. The selectItem
component only delivers the AttributeChangeEvent
event. You must create a valueChangeListener
handler or an attributeChangeListener
handler, or both for them.
The selectBooleanCheckbox
component value must always be set to a boolean and not an object. It toggles between selected and unselected states, as shown in Figure 11-23.
Figure 11-23 selectBooleanCheckbox Component
component also provides a third mixed state that indicates that the component is neither selected or cleared, as shown in Figure 11-24. Clicking a mixed state checkbox makes it selected. It toggles between the selected and cleared states, but it does not return to the mixed state by clicking, or any other click action.
Figure 11-24 selectBooleanCheckbox Component in Mixed State
The selectBooleanRadio
component displays a boolean choice, and must always be set to a boolean. Unlike the selectBooleanCheckbox
component, the selectBooleanRadio
component allows you to group selectBooleanRadio
components together using the same group
attribute.
For example, say you have one boolean that determines whether or not a user is age 10 to 18 and another boolean that determines whether a user is age 19-100. As shown in Figure 11-25, the two selectBooleanRadio
components can be placed anywhere on the page, they do not have to be next to each other. As long as they share the same group
value, they will have mutually exclusive selection, regardless of their physical placement on the page.
Tip:
Each selectBooleanRadio
component must be bound to a unique boolean.
Figure 11-25 selectBooleanRadio Component
You use the selectOneRadio
component to create a list of radio buttons from which the user can select a single value from a list, as shown in Figure 11-26.
You use the selectManyCheckbox
component to create a list of checkboxes from which the user can select one or more values, as shown in Figure 11-27.
Figure 11-27 selectManyCheckbox Component
The selectOneListbox
component creates a component which allows the user to select a single value from a list of items displayed in a shaded box, as shown in Figure 11-28.
Figure 11-28 selectOneListbox Component
The selectManyListbox
component creates a component which allows the user to select many values from a list of items. This component includes an All checkbox that is displayed at the beginning of the list of checkboxes, as shown in Figure 11-29.
Figure 11-29 selectManyListbox Component
The selectOneChoice
component creates a menu-style component, which allows the user to select a single value from a dropdown list of items. The selectOneChoice
component is intended for a relatively small number of items in the dropdown list.
Best Practice:
If a large number of items is desired, use an inputComboboxListOfValues
component instead. See Using List-of-Values Components.
The selectOneChoice
component is shown in Figure 11-30.
Figure 11-30 selectOneChoice Component
You can configure the selectOneChoice
component to display in a compact mode, as shown in Figure 11-31. When in compact mode, the input field is replaced with a smaller icon.
Figure 11-31 selectOneChoice Component in Compact Mode
When the user clicks the icon, the dropdown list is displayed, as shown in Figure 11-32.
Figure 11-32 List for selectOneChoice Component in Compact Mode
The selectManyChoice
component creates a menu-style dropdown component, which allows the user to select multiple values from a dropdown list of items. This component can be configured to include an All selection item that is displayed at the beginning of the list of selection items. If the number of choices is greater than 15, a scrollbar will be presented, as shown in Figure 11-33.
Figure 11-33 selectManyChoice Component
By default, all selectItem
child components are built when the selectManyChoice
component is built, as the page is rendered. However, if the way the list items are accessed is slow, then performance can be hampered. This delay can be especially troublesome when it is likely that the user will select the items once, and then not change them on subsequent visits.
For example, suppose you have a selectManyChoice
component used to filter what a user sees on a page, and that the values for the child selectItem
components are accessed from a web service. Suppose also that the user is not likely to change that selection each time they visit the page. By default, each time the page is rendered, all the selectItems
must be built, regardless of whether or not the user will actually need to view them. Instead, you can change the contentDelivery
attribute on the selectManyChoice
component from immediate
(the default) to lazy
. The lazy
setting causes the selectItem
components to be built only when the user clicks the dropdown.
For both immediate
and lazy
, when the user then makes a selection, the values of the selected selectItem
components are displayed in the field. However when lazy content delivery is used, on subsequent visits, instead of pulling the selected values from the selectItem
components (which would necessitate building these components), the values are pulled from the lazySelectedLabel
attribute. This attribute is normally bound to a method that returns an array of Strings
representing the selected items. The selectItem
components will not be built until the user goes to view or change them, using the dropdown.
Note that there are limitations when using the lazy
delivery method on the selectManyChoice
component. For information about content delivery for the selectManyChoice
component and its limitations, see What You May Need to Know About the contentDelivery Attribute on the SelectManyChoice Component.
For the following components, if you want the label to appear above the control, you can place them in a panelFormLayout
component.
selectOneChoice
selectOneRadio
selectOneListbox
selectManyChoice
selectManyCheckbox
selectManyListbox
For the following components, the attributes disabled
, immediate
, readOnly
, required
, requireMessageDetail
, and value
cannot be set from JavaScript on the client for security reasons (see How to Set Property Values on the Client):
selectOneChoice
selectOneRadio
selectOneListbox
selectBooleanRadio
selectManyChoice
selectManyCheckbox
selectManyListbox
The procedures for adding selection components are the same for each of the components. First, you add the selection component and configure its attributes. Then you add any number of selectItem
components for the individual items in the list, and configure those.
Before you begin:
It may be helpful to have an understanding of how the attributes can affect functionality. See Using Selection Components.
To use a selection component:
When the contentDelivery
component is set to immediate
(the default), the following happens:
First visit to the page:
and all selectItem
components are built as the page is rendered. This can cause performance issues if there are many items, or if the values for the selectItem
components are accessed for example, from a web service.
When the selectManyChoice
component renders, nothing displays in the field, as there has not yet been a selection.
When user clicks drop down, all items are shown.
When user selects items, the corresponding labels for the selected selectItem
components are shown in field.
When page is submitted, values are posted back to the model.
Subsequent visit: The selectManyChoice
and all selectItem
components are built again as the page is rendered. Labels for selected selectItem
components are displayed in field. This will cause the same performance issues as on the first visit to the page.
component is set to lazy
is built as the page is rendered, but the selectItem
components are not.
When user clicks drop down, the selectItem
components are built. While this is happening, the user sees a "busy" spinner. Once the components are built, all items are shown.
Subsequent visit:
When page is first rendered, only the selectManyChoice
component is built. At this point, the value of the lazySelectedLabel
attribute is used to display the selected items.
If user clicks drop down, the selectItem
Once the selectItem
components are built, the selectManyChoice
component will act as though its contentDelivery
attribute is set to immediate
, and use the actual value of the selectItem
components to display the selected items.
Following are limitations for using lazy content delivery for the selectManyChoice
component:
You cannot store the value of the selectManyChoice
in Request scope. On postback, the value attribute is accessed from the model, rather than decoding what was returned from the client. If the value is stored in Request scope, that value will be empty. Do not store the value in Request scope.
On postbacks, converters are not called. If you are relying on converters for postbacks, then you should not use lazy content delivery.
The ADF shuttle components comprises of two list boxes and buttons to move items from one list box to the other. You can allow users to make a single or multiple selection from the available list of values box and add it to the selected list of values box.
The selectManyShuttle
and selectOrderShuttle
components present the user with two list boxes and buttons to move or shuttle items from one list box to the other. The user can select a single item or multiple items to shuttle between the leading (Available values) list box and the trailing (Selected values) list box. For either component, if you want the label to appear above the control, place them in a panelFormLayout
component.
component is shown in Figure 11-34.
The selectOrderShuttle
component additionally includes up and down arrow buttons that the user can use to reorder values in the Selected values list box, as shown in Figure 11-35. When the list is reordered, a ValueChangeEvent
event is delivered. If you set the readOnly
attribute to true
, ensure the values to be reordered are selected values that will be displayed in the trailing list (Selected values).
Figure 11-35 selectOrderShuttle Component
The value
attribute of these components, like any other selectMany
component, must be a List
or an Array
of values that correspond to a value of one of the contained selectItem
components. If a value of one of the selectItems
is in the List
or Array
, that item will appear in the trailing list. You can convert a selectManyListbox
component directly into a selectManyShuttle
; instead of the value
driving which items are selected in the listbox, it affects which items appear in the trailing list of the selectOrderShuttle
component.
Similar to other select components, the List or Array of items are composed of selectItem
components nested within the selectManyShuttle
or selectOrderShuttle
component. The following example shows a sample selectOrderShuttle
component that allows the user to select the top five file types from a list of file types.
<af:selectOrderShuttle value="#{helpBean.topFive}" leadingHeader="#{explorerBundle['help.availableFileTypes']}" trailingHeader="#{explorerBundle['help.top5']}" simple="true" id="sos1"> <af:selectItem label="XLS" id="si1"/> <af:selectItem label="DOC" id="si2"/> <af:selectItem label="PPT" id="si3"/> <af:selectItem label="PDF" id="si4"/> <af:selectItem label="Java" id="si5"/> <af:selectItem label="JWS" id="si6"/> <af:selectItem label="TXT" id="si7"/> <af:selectItem label="HTML" id="si8"/> <af:selectItem label="XML" id="si9"/> <af:selectItem label="JS" id="si10"/> <af:selectItem label="PNG" id="si11"/> <af:selectItem label="BMP" id="si12"/> <af:selectItem label="GIF" id="si13"/> <af:selectItem label="CSS" id="si14"/> <af:selectItem label="JPR" id="si15"/> <af:selectItem label="JSPX" id="si16"/> <f:validator validatorId="shuttle-validator"/> </af:selectOrderShuttle>
If you set the reorderOnly
attribute of a selectOrdershuttle
component to true
, the shuttle function will be disabled, and only the Selected Values listbox appears. The user can only reorder the items in the listbox, as shown in Figure 11-36.
Figure 11-36 selectOrderShuttle Component in Reorder-Only Mode
The procedures for adding shuttle components are the same for both components. First you add the selection component and configure its attributes. Then you add any number of selectItem
Before you begin:
It may be helpful to have an understanding of how the attributes can affect functionality. See Using Shuttle Components.
To add a selectManyShuttle or selectOrderShuttle component:
You can provide the user with information about each selected item before the user shuttles it from one list to another list by creating JavaScript code to perform processing in response to the event of selecting an item. For example, your code can obtain additional information about that item, then display it as a popup to help the user make the choice of whether to shuttle the item or not. Figure 11-37 shows a selectManyShuttle
component in which the user selects Meyers and a popup provides additional information about this selection.
Figure 11-37 selectManyShuttle with selectionListener
You implement this feature by adding a client listener to the selectManyShuttle
component and then create a JavaScript method to process this event. The JavaScript code is executed when a user selects an item from the lists. For information about using client listeners for events, see Listening for Client Events.
How to add a client listener to a shuttle component to handle a selection event:
In the following example, AdfShuttleUtils.getLastSelectionChange
is called to get the value of the last selected item
function showDetails(event)
if(AdfRichSelectManyShuttle.SELECTION == event.getPropertyName())
var shuttleComponent = event.getSource();
var lastChangedValue = AdfShuttleUtils.getLastSelectionChange(shuttleComponent, event.getOldValue());
var side = AdfShuttleUtils.getSide(shuttleComponent, lastChangedValue);
if(AdfShuttleUtils.isSelected(shuttleComponent, lastChangedValue))
//do something...
else
//do something else
if(AdfShuttleUtils.isLeading(shuttleComponent, lastChangedValue))
//queue a custom event (see serverListener) to call a java method on the server
Using the ADF richTextEditor component you can allow users to edit and add formatted input content. The richTextEditor provides several options to format the content.
The richTextEditor
component provides an input field that can accept text with formatting. It also supports label text, and messages. It allows the user to change font name, size, and style, create ordered lists, justify text, and use a variety of other features. The richTextEditor
component also can be used to edit an HTML source file. Two command buttons are used to toggle back and forth between editing standard formatted text and editing the HTML source file. Figure 11-38 shows the rich text editor component in standard rich text editing Mode.
Figure 11-38 The richTextEditor Component in Standard Editing Mode
Figure 11-39 shows the editor in source code editing mode.
Figure 11-39 richTextEditor in Source Editing Mode
Other supported features include:
Font type
Font size
Link/unlink
Clear styling
Undo/redo
Bold/italics/underline
Subscript/superscript
Justify (left, middle, right, full)
Ordered/unordered lists
Indentation
Text color/background color
Rich text editing mode / source code editing mode
Rich text editing toolbar inline display mode / popup display mode
The value (entered text) of the rich text editor is a well-formed XHTML fragment. Parts of the value may be altered for browser-specific requirements to allow the value to be formatted. Also, for security reasons, some features such as script-related tags and attributes will be removed. There are no guarantees that this component records only the minimal changes made by the user. Because the editor is editing an XHTML document, the following elements may be changed:
Nonmeaningful whitespace
Element minimization
Element types
Order of attributes
Use of character entities
The editor supports only HTML 4 tags, with the exception of:
Script, noscript
Frame, frameset, noframes
Form-related elements (input, select, optgroup, option, textarea, form, button, label, isindex)
Document-related elements (html, head, body, meta, title, base, link)
The richTextEditor
component provides a footer facet that you can use to display additional information, or to add user interface elements. For example, Figure 11-40 shows the richTextEditor
component with a character counter in its footer facet.
Figure 11-40 The richTextEditor Component with Character Counter in Footer Facet
The richTextEditor
component also supports tags that pull in content (such as applet
, iframe
, object
, img
, and a
). For the iframe
tag, the content should not be able to interact with the rest of the page because browsers allow interactions only with content from the same domain. However, this portion of the page is not under the control of the application.
While the richTextEditor
component does not support font units such as px
and em
, it does support font size from 1 to 7 as described in the HTML specification. It does not support embed or unknown tags (such as <foo>
On the client, the richTextEditor
component does not support getValue
and setValue
methods. There is no guarantee the component's value on the client is the same as the value on the server. Therefore, the richTextEditor
does not support client-side converters and validators. Server-side converters and validators will still work.
The rich text editor delivers ValueChangeEvent
events. Create valueChangeListener
and attributeChangeListener
handlers for these events as required.
You can also configure the richTextEditorInsertBehavior
tag, which works with command components to insert given text into the richTextEditor
component. The text to be entered can be a simple string, or it can be preformatted text held, for example, in a managed bean.
By default, the toolbar in the richTextEditor
component allows the user to change many aspects of the text, such as the font, font size and weight, text alignment, and view mode, as shown in Figure 11-41.
Figure 11-41 Toolbar in richTextEditor Component
Figure 11-42 shows a toolbar that has been customized. Many of the toolbar buttons have been removed and a toolbar with a custom toolbar button and a menu have been added.
Figure 11-42 Customized Toolbar for richTextEditor
As Figure 11-43 shows, you can configure the toolbar to display in popup mode when displaying the toolbar inline (default behavior) with the richTextEditor
is not desired.
Figure 11-43 Toolbar Display Mode Set to Popup
Once you add a richTextEditor
component, you can configure it so that text can be inserted at a specific place, and you can also customize the toolbar. See How to Add the Ability to Insert Text into a richTextEditor Component, and How to Customize the Toolbar.
Before you begin:
It may be helpful to have an understanding of how the attributes can affect functionality. See Using the richTextEditor Component.
To add a richTextEditor component:
Tip:
You can set the width of a richTextEditor
component to full width or 100%. However, this works reliably only if the editor is contained in a geometry-managing parent components. It may not work reliably if it is placed in flowing layout containers such as panelFormLayout
or panelGroupLayout
. See Geometry Management and Component Stretching.
To allow text to be inserted into a richTextEditor
component, add the richTextEditorInsertBehavior
Before you begin:
It may be helpful to have an understanding of the rich text editor component. See Using the richTextEditor Component.
You need to create a richTextEditor
component as described in How to Add a richTextEditor Component. Set the clientComponent
attribute to true
Place the toolbar and toolbar buttons you want to add in custom facets that you create. Then, reference the facet (or facets) from an attribute on the toolbar, along with keywords that determine how or where the contained items should be displayed.
Before you begin:
To customize the toolbar:
The ADF allows you to provide the input by uploading single or multiple files. You can also update the already submitted file.
The inputFile
component provides users with file uploading and updating capabilities. This component allows the user to select a local file and upload it to a selectable location on the server (to download a file from the server to the user, see How to Use an Action Component to Download Files).
The inputFile
component delivers the standard ValueChangeEvent
event as files are being uploaded, and it manages the loading process transparently. The value
property of an inputFile
component is set to an instance of the org.apache.myfaces.trinidad.model.UploadedFile
class when the file is uploaded.
To initiate the upload process you first must configure the page's form to allow uploads. You then create an action component such as a command button, as shown in Figure 11-44, that can be used to upload a file.
Once a file has been uploaded, and so the value of the inputFile
is not null (either after the initial load is successful or it has been specified as an initial value), you can create an Update button that will be displayed instead of the Browse button, as shown in Figure 11-45. This will allow the user to modify the value of the inputFile
component.
Figure 11-45 inputFile Component in Update Mode
Setting the uploadType
attribute to auto or manual displays the progress bar while uploading a file as shown in Figure 11-46.
Figure 11-46 inputFile Component with Progress Bar
You can also specify that the component be able to load only a specific file by setting the readOnly
property to true
, In this mode, only the specified file can be loaded, as shown in Figure 11-47.
Figure 11-47 inputFile Component in Read-Only Mode
By default, the inputFile
component allows upload of one file only, but it can be configured to upload multiple files. Figure 11-48 shows the inputFile
component configured to upload multiple files.
Figure 11-48 inputFile Component for Multiple Files
The user can select multiple files in the File Upload dialog that opens through the Browse button, or drag-and-drop multiple files in the drop section of the component. When files appear in the drop section, the user clicks Upload to upload the files, as shown in Figure 11-49.
Figure 11-49 inputFile Component Showing Files Ready to Upload
Using Javascript APIs, you can configure the inputFile
component to utilize custom user interface elements. For example, Figure 11-50 shows the inputFile
component with a description field that the user may use to enter a brief description of the selected file.
Figure 11-50 inputFile Component with Custom User Interface Element
For information about Javascript APIs that you can use to configure the inputFile
component, see the documentation of class AdfFileUploadManager
in JavaScript API Reference for Oracle ADF Faces.
The inputFile
component can be placed in either an h:form
tag or an af:form
tag, but in either case, you have to set the form tag to support file upload. If you use the JSF basic HTML h:form
, set the enctype
to multipart/form-data
. This would make the request into a multipart request to support file uploading to the server. If you are using the ADF Faces af:form
tag, set usesUpload
to true
, which performs the same function as setting enctype
The ADF Faces framework performs a generic upload of the file. You should create an actionListener
or action method to process the file after it has been uploaded (for example, processing xml
files, pdf
files, and so on).
The value
of an inputFile
component is an instance of the org.apache.myfaces.trinidad.model.UploadedFile
interface. Thus, when the file is uploaded, the value of the inputFile
component becomes the instance of org.apache.myfaces.trinidad.model.UploadedFile
. Therefore, if you need to access the value (that is, the file itself), you need to use the API for this interface. Accessing the component itself through the binding
attribute only accesses the component and not the uploaded file.
The API of the org.apache.myfaces.trinidad.model.UploadedFile
interface lets you get at the actual byte stream of the file, as well as the file's name, its MIME type, and its size. The API does not allow you to get path information from the client about from where the file was uploaded.
The uploaded file may be stored as a file in the file system, but may also be stored in memory; the API hides that difference. The filter ensures that the UploadedFile
content is cleaned up after the request is complete. Because of this, you cannot usefully cache UploadedFile
objects across requests. If you need to keep the file, you must copy it into persistent storage before the request finishes.
For example, instead of storing the file, add a message stating the file upload was successful using a managed bean as a response to the ValueChangeEvent
event, as shown in Example 11-1.
You can also handle the upload by binding the value directly to a managed bean, as shown in Example 11-2.
If you are using the inputFile
component to upload multiple files, note that the return type of event.getNewValue()
is List<UploadedFile>
, instead of UploadedFile
. The value binding for the managed bean is also List<UploadedFile>
, not UploadedFile
Example 11-1 Using valueChangeListener to Display Upload Message
JSF Page Code -----> <af:form usesUpload="true" id="f1"> <af:inputFile label="Upload:" valueChangeListener="#{managedBean.fileUploaded}" id="if1"/> <af:button text="Begin" id="b1"/> </af:form> Managed Bean Code ----> import javax.faces.application.FacesMessage; import javax.faces.context.FacesContext; import javax.faces.event.ValueChangeEvent; import org.apache.myfaces.trinidad.model.UploadedFile; public class ABackingBean { ... public void fileUploaded(ValueChangeEvent event) { UploadedFile file = (UploadedFile) event.getNewValue(); if (file != null) { FacesContext context = FacesContext.getCurrentInstance(); FacesMessage message = new FacesMessage( "Successfully uploaded file " + file.getFilename() + " (" + file.getLength() + " bytes)"); context.addMessage(event.getComponent().getClientId(context), message); // Here's where we could call file.getInputStream() } } }
Example 11-2 Example 11-13 Binding the Value to a Managed Bean
JSF Page Code ----> <af:form usesUpload="true"> <af:inputFile label="Upload:" value="#{managedBean.file}" id="if1"/> <af:button text="Begin" action="#{managedBean.doUpload}" id="b1"/> </af:form> Managed Bean Code ----> import org.apache.myfaces.trinidad.model.UploadedFile;public class AManagedBean { public UploadedFile getFile() { return _file; } public void setFile(UploadedFile file) { _file = file; } public String doUpload() { UploadedFile file = getFile(); // ... and process it in some way } private UploadedFile _file; }
A Java class must be bound to the inputFile
component. This class will be responsible for containing the value of the uploaded file.
Before you begin:
It may be helpful to have an understanding of how the attributes can affect functionality. See Using File Upload.
To add an inputFile component:
Use the uploadType
and maximumFiles
attributes to configure the inputFile
component to upload multiple files.
Before you begin:
To configure an inputFile component to upload multiple files:
To remove an uploaded file from the drop section, or cancel upload of a file that is being uploaded, click the Cancel icon next to the file name and the progress bar. To cancel upload of all files, click the Stop Uploading button, as shown in Figure 11-51.
Figure 11-51 File Being Uploaded Using inputFile Component
Because ADF Faces will temporarily store files being uploaded (either on disk or in memory), by default it limits the size of acceptable incoming upload requests to avoid denial-of-service attacks that might attempt to fill a hard drive or flood memory with uploaded files. By default, only the first 100 kilobytes in any one request will be stored in memory. Once that has been filled, disk space will be used. Again, by default, that is limited to 2,000 kilobytes of disk storage for any one request for all files combined. Once these limits are exceeded, the filter will throw an EOFException
Files are, by default, stored in the temporary directory used by the java.io.File.createTempFile()
method, which is usually defined by the system property java.io.tmpdir
. Obviously, this will be insufficient for some applications, so you can configure these values using three servlet context initialization parameters, as shown in the following example.
<context-param> <!-- Maximum memory per request (in bytes) --> <param-name>org.apache.myfaces.trinidad.UPLOAD_MAX_MEMORY</param-name> <!-- Use 500K --> <param-value>512000</param-value> </context-param> <context-param> <!-- Maximum disk space per request (in bytes) --> <param-name>org.apache.myfaces.trinidad.UPLOAD_MAX_DISK_SPACE</param-name> <!-- Use 5,000K --> <param-value>5120000</param-value> </context-param> <context-param> <!-- directory to store temporary files --> <param-name>org.apache.myfaces.trinidad.UPLOAD_TEMP_DIR</param-name> <!-- Use a TrinidadUploads subdirectory of /tmp --> <param-value>/tmp/TrinidadUploads/</param-value> </context-param> <context-param> <!-- Maximum file size that can be uploaded.--> <param-name>org.apache.myfaces.trinidad.UPLOAD_MAX_FILE_SIZE</param-name> <!-- Use 5,000K --> <param-value>5120000</param-value> </context-param> <!-- This filter is always required; one of its functions is file upload. --> <filter> <filter-name>trinidad</filter-name> <filter-class>org.apache.myfaces.trinidad.webapp.TrinidadFilter</filter-class> </filter>
You can customize the file upload process by replacing the entire org.apache.myfaces.trinidad.webapp.UploadedFileProcessor
class with the <uploaded-file-processor>
element in the trinidad-config.xml
configuration file. Replacing the UploadedFileProcessor
class makes the parameters listed in the previous example irrelevant, they are processed only by the default UploadedFileProcessor
class.
The <uploaded-file-processor>
element must be the name of a class that implements the oracle.adf.view.rich.webapp.UploadedFileProcessor
interface. This API is responsible for processing each individual uploaded file as it comes from the incoming request, and then making its contents available for the rest of the request. For most applications, the default UploadedFileProcessor
class is sufficient, but applications that need to support uploading very large files may improve their performance by immediately storing files in their final destination, instead of requiring ADF Faces to handle temporary storage during the request.
The inputFile
component uses HTML 5 to support the drag-and-drop functionality and upload of multiple files. In browsers that do not support HTML 5, a Java applet is used for drag-and-drop functionality and upload of multiple files, as shown in Figure 11-52.
Figure 11-52 inputFile Component in a Non-HTML 5 Browser
If the browser does not support HTML5 and Java is also not available, then the drop section in the inputFile
component is not displayed.
The inputFile
component can only upload files that are smaller than 2 GB when in single file upload mode. In multiple file upload mode, the inputFile
component can upload files greater than 2 GB, by default, by splitting them into chunks of 2 GB in size. The chunk size can be controlled by the parameter org.apache.myfaces.trinidad.UPLOAD_MAX_CHUNK_SIZE
in web.xml
whose default and maximum value is 2 GB. For example:
<context-param> <!-- Maximum file chunk size that can be uploaded.--> <param-name>org.apache.myfaces.trinidad.UPLOAD_MAX_CHUNK_SIZE</param-name> <!-- Use 1,000 MB as chunk size --> <param-value>1000000000</param-value> </context-param>
Note that not all browsers support the uploading of large files using the chunk functionality. For information about the browser certification, see the Certification Information page on the Oracle Technology Network at:
http://www.oracle.com/technetwork/developer-tools/jdev/ documentation/index.html
After uploading all files, you must ensure that the form is submitted, else the inputFile
component data will not be uploaded to the server. If autoSubmit
is set to true
on the inputFile
component, then the form is submitted automatically after all the files have finished uploading. After the form has been submitted, the inputFile
component is refreshed and the file list of the drop section becomes empty so that more files can be uploaded. To show the list of uploaded files, add ValueChangeListener
or bind the value to a managed bean, as described in Example 11-1.
You can customize the user interface of the inputFile
component with the displayMode
attribute. If the displayMode
attribute is set to none,
no user interface is displayed, and as a developer you will need to create a custom user interface to invoke the APIs to upload files. If the attribute is set to dropArea
, a drop area is rendered that supports drag and drop of files, and you will be responsible for adding the rest of the custom user interface. The customized interface of the inputFile
component is visible only when it is configured to upload multiple files.
Figure 11-53 shows the inputFile
component with different values for displayMode
Figure 11-53 displayMode Attribute Values for inputFile Component
The following example shows an inputFile
component with displayMode
set to dropArea
, and customized to add input fields and buttons to browse and upload files. An additional inputText
component is added to enter the description of the uploaded file.
<af:inputFile binding="#{editor.component}" id="bound1" immediate="true" maximumFiles="-1"valueChangeListener="#{demoFile.fileUpdate}" displayMode="dropArea" uploadType="manual"contentStyle="width:200px; height:100px"/> <af:panelFormLayout maxColumns="2" rows="1"> <input type="file" id="dmoTpl:cidf1"/> <af:inputText clientComponent="true" id="cidd1" label="Please Enter a Description"/> </af:panelFormLayout> <af:panelFormLayout maxColumns="2" rows="2"> <af:panelLabelAndMessage for="cidn1" label="Filename:" id="plm1"> <af:outputText clientComponent="true" id="cidn1"/> </af:panelLabelAndMessage> <af:panelLabelAndMessage for="cids1" label="Filesize:" id="plm2"> <af:outputText clientComponent="true" id="cids1"/> </af:panelLabelAndMessage> <af:panelLabelAndMessage for="cidp1" label="% Complete:" id="plm3"> <af:outputText clientComponent="true" id="cidp1"/> </af:panelLabelAndMessage> <af:panelLabelAndMessage for="cidst1" label="Status:" id="plm4"> <af:outputText clientComponent="true" id="cidst1"/> </af:panelLabelAndMessage> </af:panelFormLayout> <af:panelFormLayout maxColumns="2" rows="1"> <af:button id="cup1" text="Upload"> <af:clientListener method="uploadClick" type="click"/> </af:button> <af:button id="cl1" text="Clear"> <af:clientListener method="clearQueue" type="click"/> </af:button> </af:panelFormLayout>
Figure 11-54 shows the inputFile
component at runtime.
Figure 11-54 Customized inputFile Component
You can use the JavaScript API methods to customize the behavior of inputFile
component. See the JavaScript API Reference for Oracle ADF Faces.
Using the code editor users can edit the code on the go during runtime. This is achieved using ADF af:codeEditor component.
The af:codeEditor
component provides an in-browser code editing solution and enables the user to display and edit program code at runtime in the Fusion web application. The input field of the code editor component accepts text, and provides some common code editing functionalities such as a toolbar, syntactical color coding of keywords, code completion, basic validation, highlighting errors, and a message pane for logs. Using the code editor, the user won't need to run separate IDE software to test program code for errors or warnings.
The code editor component supports Javascript, XML, and Groovy languages, as shown in Figure 11-55.
Figure 11-55 Code Editor Component using Javascript, XML, and Groovy
The code editor component provides the following functionalities:
Line numbering
Undo and redo operations (also possible using keyboard shortcuts Ctrl+Z and Ctrl+Y)
Jump to a specific line
Find and replace
Color-coded text
Highlighting syntaxes and search terms
Code completion
Auto-indent
Auto-format
Message pane for error messages
Support for large files with more than thousand lines of code
To add or edit code in code editor, the user can simply click in the editor area and start typing. Control+Spacebar displays a contextual list of hints for code completion. To use other editing features, press F2 to enable edit mode. Once in edit mode, the user can use Tab to indent and Shift+Tab to backward-indent a line of code. With edit mode disabled, Tab and Shift+Tab provide navigation to the next and previous components.
The user can use the toolbar (shown in Figure 11-56) to undo and redo the changes, search and replace text, and jump to a specific line number.
Figure 11-56 Code Editor Toolbar
To search for a string, enter the search term in the Find field, and click Find Next or Find Previous icons to locate the search string in the code editor. Figure 11-57 shows the Find field of the toolbar used to search a string in the code editor.
Figure 11-57 Using the Find Field of Code Editor Toolbar
To search a case sensitive string, or replace a search term, open the Find and Replace dialog from the Find and Replace icon, and perform the operations from the dialog, as shown in Figure 11-58.
Figure 11-58 Using Find and Replace Dialog of Code Editor
If the Whole Words checkbox is selected, the Find and Replace dialog cannot search for a non-English string in the editor. However, using the Replace All button, you can replace all instances of the non-English string while the Whole Words checkbox is selected.
To jump to a specific line number, enter the number in the Go to Line field and click Jump to line, as shown in Figure 11-59.
Figure 11-59 Using Go To Line Feature of Code Editor
The code editor component can be configured to list all warnings and errors in a message pane that is also provided with the code editor component. Figure 11-60 shows the message pane listing all XML errors noticed by the XML parser running on the server.
Figure 11-60 Message Pane of Code Editor
The message pane is a non-editable region that resides below the text area of the code editor. It is used to display code-related status information, such as validation support for code compilation, and any error or warning messages. Clicking a message in the message pane navigates you to the respective code line in the code editor.
You can also configure the code editor to programmatically add various types of markers. Figure 11-61 shows the code editor with critical error, error, warning, and information markers.
Figure 11-61 Using Markers in Code Editor
When you add a codeEditor
component, use the language
attribute to configure the programming language used by the code editor.
Before you begin:
It may be helpful to have an understanding of how the attributes can affect functionality. See Using Code Editor.
To add a codeEditor component:
