man pages section 3: Curses Library Functions
Exit Print View
Updated: July 2014
def_shell_mode(3XCURSES)
Name
def_prog_mode, def_shell_mode, reset_prog_mode, reset_shell_mode - save/restore terminal modes
Synopsis
cc [ flag... ] file... –I /usr/xpg4/include –L /usr/xpg4/lib \
–R /usr/xpg4/lib –lcurses [ library... ]
c89 [ flag... ] file... –lcurses [ library... ]
#include <curses.h>
int def_prog_mode(void);
int def_shell_mode(void);
int reset_prog_mode(void);
int reset_shell_mode(void);
Description
The def_prog_mode() and def_shell_mode() functions save the current terminal modes as "program" (within X/Open Curses) or "shell" (outside X/Open Curses). The modes are saved automatically by initscr(3XCURSES), newterm(3XCURSES), and setupterm(3XCURSES).
The reset_prog_mode() and reset_shell_mode() functions reset the current terminal modes to "program" (within X/Open Curses) or "shell" (outside X/Open Curses). The endwin(3XCURSES) function automatically calls the reset_shell_mode() function and the doupdate(3XCURSES) function calls the reset_prog_mode() function after calling endwin().
Return Values
On success, these functions return OK. Otherwise, they return ERR.
Errors
None.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
Unsafe
Standard
See also
endwin(3XCURSES), initscr(3XCURSES), libcurses(3XCURSES), newterm(3XCURSES), setupterm(3XCURSES), attributes(5), standards(5)
