man pages section 3: Curses Library Functions
Exit Print View
Updated: July 2014
echo_wchar(3XCURSES)
Name
echo_wchar, wecho_wchar - add a complex character and refresh window
Synopsis
cc [ flag... ] file... –I /usr/xpg4/include –L /usr/xpg4/lib \
–R /usr/xpg4/lib –lcurses [ library... ]
c89 [ flag... ] file... –lcurses [ library... ]
#include <curses.h>
int echo_wchar(const cchar_t *wch);
int wecho_wchar(WINDOW *win, const cchar_t *wch);
Description
The echo_wchar() function produces the same effect as calling add_wch(3XCURSES) and then refresh(3XCURSES). The wecho_wchar() function produces the same effect as calling wadd_wch(3XCURSES) and then wrefresh(3XCURSES).
Parameters
wch
Is a pointer to the complex character to be written to the window.
win
Is a pointer to the window in which the character is to be added.
Return Values
On success, these functions return OK. Otherwise, they return ERR.
Errors
None.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
Unsafe
Standard
See also
add_wch(3XCURSES), doupdate(3XCURSES), echochar(3XCURSES), libcurses(3XCURSES), attributes(5), standards(5)
