man pages section 3: Curses Library Functions
Exit Print View
Updated: July 2014
panel_below(3CURSES)
Name
panel_above, panel_below - panels deck traversal primitives
Synopsis
cc [ flag ... ] file ... –lpanel –lcurses [ library .. ]
#include <panel.h>
PANEL *panel_above(PANEL *panel);
PANEL *panel_below(PANEL *panel);
Description
panel_above() returns a pointer to the panel just above panel, or NULL if panel is the top panel. panel_below() returns a pointer to the panel just below panel , or NULL if panel is the bottom panel.
If NULL is passed for panel, panel_above() returns a pointer to the bottom panel in the deck, and panel_below() returns a pointer to the top panel in the deck.
Return Values
NULL is returned if an error occurs.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
MT-Level
Unsafe
See also
curses(3CURSES), panels(3CURSES), attributes(5)
Notes
These routines allow traversal of the deck of currently visible panels.
The header <panel.h> automatically includes the header <curses.h>.
