man pages section 3: Curses Library Functions
Exit Print View
Updated: July 2014
raw(3XCURSES)
Name
cbreak, nocbreak, noraw, raw - set input mode controls
Synopsis
cc [ flag... ] file... –I /usr/xpg4/include –L /usr/xpg4/lib \
–R /usr/xpg4/lib –lcurses [ library... ]
c89 [ flag... ] file... –lcurses [ library... ]
#include <curses.h>
int cbreak(void);
int nocbreak(void);
int noraw(void);
int raw(void);
Description
The cbreak() function enables the character input mode. This overrides any previous call to the raw() function and turns the stty flag ICANON off.
The nocbreak() function sets the line canonical mode and turns the stty flag ICANON on without touching the ISIG or IXON flags.
The noraw() function sets the line canonical mode and turns the stty flags ICANON, ISIG, and IXON all on.
The raw() function sets the character input mode and turns the stty flags ICANON, ISIG, and IXON all off. This mode provides maximum control over input.
It is important to remember that the terminal may or may not be in character mode operation initially. Most interactive programs require cbreak() to be enabled.
Return Values
On success, these functions return OK. Otherwise, they return ERR.
Errors
None.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
Unsafe
Standard
See also
getch(3XCURSES), halfdelay(3XCURSES), nodelay(3XCURSES), timeout(3XCURSES), libcurses(3XCURSES), attributes(5), standards(5), termio(7I)
