man pages section 3: Curses Library Functions
Exit Print View
Updated: July 2014
field_info(3CURSES)
Name
form_field_info, field_info , dynamic_field_info - get forms field characteristics
Synopsis
cc [ flag... ] file... –lform –lcurses [ library... ]
#include <form.h>
int field_info(FIELD *field, int *rows, int *cols, int *frow, int *fcol,
     int *nrow, int *nbuf);
int dynamic_field_info(FIELD *field, int *drows, int *dcols, int *max);
Description
field_info() returns the size, position, and other named field characteristics, as defined in the original call to new_field(), to the locations pointed to by the arguments rows, cols, frow, fcol, nrow, and nbuf.
dynamic_field_info() returns the actual size of the field in the pointer arguments drows, dcols and returns the maximum growth allowed for field in max. If no maximum growth limit is specified for field, max will contain 0. A field can be made dynamic by turning off the field option O_STATIC.
Return Values
These routines return one of the following:
E_OK
The function returned successfully.
E_SYSTEM_ERROR
System error.
E_BAD_ARGUMENT
An argument is incorrect.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
MT-Level
Unsafe
See also
curses(3CURSES), forms(3CURSES), attributes(5)
Notes
The header <form.h> automatically includes the headers <eti.h> and <curses.h>.
