Table 29. Business Service Methods Syntax Summary
GetFirstProperty Method |
Retrieves the name of the first property of a business service. |
Dim oService as SiebelService Dim sName as String sName = oService.GetFirstProperty(ErrCode as Integer)
GetNextProperty Method |
Once the name of the first property has been retrieved, retrieves the name of the next property of a business service. |
Dim oService as SiebelService Dim sName as String sName = oService.GetNextProperty(ErrCode as Integer)
GetProperty Method |
Retrieves the value stored in the specified property. |
Dim oService as SiebelService Dim sValue as String sValue = oService.GetProperty(propName as String, ErrCode as Integer)
Name Method |
Returns the name of the business service. |
Dim oService as SiebelService Dim sName as String sName = oService.Name
InvokeMethod Method |
Calls a specialized method or a user-created method on the business service. |
Dim oService as SiebelService oService.InvokeMethod(methodName as String, InputArguments as SiebelPropertySet, OutputArguments as SiebelPropertySet, ErrCode as Integer)
PropertyExists Method |
Returns a Boolean value indicating whether the property specified in the argument exists. |
Dim oService as SiebelService Dim propExists as Boolean propExists = oService.PropertyExists( propName as String)
RemoveProperty Method |
Removes a property from a business service. |
Dim oService as SiebelService oService.RemoveProperty(propName as String, ErrCode as Integer)
SetProperty Method |
Assigns a value to a property of a business service. |
Dim oService as SiebelService oService.SetProperty(propName as String, propValue as String, ErrCode as Integer)
