Table 30. Property Set Methods Syntax Summary
AddChild Method |
Adds subsidiary property sets to a property set. |
Dim oPropSet as SiebelPropertySet Dim iIndex as Integer iIndex = oPropSet.AddChild( childObject as Property Set, errCode as Integer)
Copy Method |
Returns a copy of a property set. |
Dim oPropSet1 as SiebelPropertySet Dim oPropSet2 as SiebelPropertySet oPropSet2 = oPropSet1.Copy(ErrCode as Integer)
GetChild Method |
Returns a specified child property set of a property set. |
Dim oPropSet as SiebelPropertySet Dim oChildPropSet as SiebelPropertySet oChildPropSet = oPropSet.GetChild( index as Integer, ErrCode as Integer)
GetChildCount Method |
Returns the number of child property sets attached to a parent property set. |
Dim oPropSet as SiebelPropertySet Dim iCount as Integer iCount = oPropSet.GetChildCount(ErrCode as Integer)
GetFirstProperty Method |
Returns the name of the first property in a property set. |
Dim oPropSet as SiebelPropertySet Dim sPropName as String sPropName = oPropSet.GetFirstProperty(ErrCode as Integer)
GetNextProperty Method |
Returns the name of the next property in a property set. |
Dim oPropSet as SiebelPropertySet Dim sPropName as String sPropName = oPropSet.GetNextProperty(ErrCode as Integer)
GetProperty Method |
Returns the value of a property when given the property name. |
Dim oPropSet as SiebelPropertySet Dim sPropVal as String sPropVal = oPropSet.GetProperty(propName as String, ErrCode as Integer)
GetPropertyCount Method |
Returns the number of properties contained within the property set. |
Dim oPropSet as SiebelPropertySet Dim propCount as Integer propCount = oPropSet.GetPropertyCount (ErrCode as Integer)
GetType Method |
Returns the value stored in a type in a property set. |
Dim oPropSet as SiebelPropertySet Dim sTypeVal as String sTypeVal = oPropSet.GetType(value as String)
GetValue Method |
Returns a value stored as part of a property set. |
Dim oPropSet as SiebelPropertySet Dim sValVal as String sValVal = oPropSet.GetValue(ErrCode as Integer)
InsertChildAt Method |
Inserts a child property set into a parent property set at a specific location. |
Dim oPropSet as SiebelPropertySet oPropSet.InsertChildAt(childObject as String, index as Integer, ErrCode as Integer)
PropertyExists Method |
Returns a Boolean value indicating whether the property specified in the argument exists. |
Dim oPropSet as Property Set Dim propExists as Boolean propExists = oPropSet.PropertyExists( propName as String, ErrCode as Integer)
RemoveChild Method |
Removes a child property set as a specified index from a parent property set. |
Dim oPropSet as SiebelPropertySet oPropSet.RemoveChild(index as Integer, errCode as Integer)
RemoveProperty Method |
Removes the property specified in its argument from a property set. |
Dim oPropSet as SiebelPropertySet oPropSet.RemoveProperty(propName as String, ErrCode as Integer)
Reset Method |
Removes every property and child property set from a property set. |
Dim oPropSet as SiebelPropertySet oPropSet.Reset(ErrCode as Integer)
SetProperty Method |
Assigns a value to the property of a property set specified in its argument. |
Dim oPropSet as SiebelPropertySet oPropSet.SetProperty(propName as String, propValue as String, ErrCode as Integer)
SetType Method |
Assigns a data value to a type member of a property set. |
Dim oPropSet as SiebelPropertySet oPropSet.SetType(value as String, ErrCode as Integer)
SetValue Method |
Assigns a data value to a value member of a property set. |
Dim oPropSet as SiebelPropertySet oPropSet.SetValue(value as String, errCode as Integer)
