Skip Navigation Links
Exit Print View
Sun Storage 6 Gb SAS PCIe RAID HBA, Internal
Installation Guide For HBA Models SGX-SAS6-R-INT-Z and SG-SAS6-R-INT-Z
Oracle Technology Network
Library
PDF
Print View
Feedback
search filter icon
search icon
Document Information
Using This Documentation
Chapter 1 HBA Overview
Chapter 2 Hardware Installation and Removal
Observing ESD and Handling Precautions
Installing the HBA
To Prepare for Hardware Installation
To Install the HBA
To Connect the HBA to Internal Storage Devices
To Complete the Installation
HBA LEDs
Next Steps
Removing the HBA
To Remove the HBA
Chapter 3 Creating a Bootable Drive in a Preboot Environment
Chapter 4 HBA Software Installation
Chapter 5 Known Issues
Appendix A HBA Specifications
Glossary
To Install the HBA
  1. Attach an antistatic wrist strap and remove the HBA from its protective bag.
    See Observing ESD and Handling Precautions.
  2. Ensure that the jumper settings on the HBA are in the desired position.
    The jumpers are set at the factory, and you usually do not need to change them. See HBA Card Layout for information about the location of the jumpers on the HBA.
  3. If a removable memory option is present, ensure that the module is seated firmly in the dual-inline memory module (DIMM) socket.
    Note - This HBA has on-board DDR2 memory.
  4. Refer to the service or installation manual for your particular system for instructions on how to locate an available PCI Express slot in the system.
  5. Align the PCI Express bus connector of the HBA to the PCI Express slot.
    Note - Some PCIe slots support PCIe graphics cards only; if the HBA is installed in one of those PCIe slots, the HBA will not function.
  6. Press down gently and firmly to seat the HBA in the PCIe slot, and then secure the bracket to the system chassis with the bracket screw (see Installing Oracle's Sun Storage 6 Gb SAS PCIe RAID HBA, Internal).
    Figure 2-1  Installing Oracle's Sun Storage 6 Gb SAS PCIe RAID HBA, Internal
    image:Figure that shows installing the host adapter board into a PCI Express slot.
    Figure Legend
    1 Bracket screw
    2Press down here
    3 x8 slots (3.3 V)
    4PCIe slot
    5 x16 slots (3.3 V)
    6Edge of motherboard
    Note - The configuration of the enclosure might not be the same as shown in this illustration.
