Skip Navigation Links
Exit Print View
Sun Storage 6 Gb SAS PCIe RAID HBA, Internal
Installation Guide For HBA Models SGX-SAS6-R-INT-Z and SG-SAS6-R-INT-Z
Oracle Technology Network
Library
PDF
Print View
Feedback
search filter icon
search icon
Document Information
Using This Documentation
Chapter 1 HBA Overview
Chapter 2 Hardware Installation and Removal
Observing ESD and Handling Precautions
Installing the HBA
To Prepare for Hardware Installation
To Install the HBA
To Connect the HBA to Internal Storage Devices
To Complete the Installation
HBA LEDs
Next Steps
Removing the HBA
To Remove the HBA
Chapter 3 Creating a Bootable Drive in a Preboot Environment
Chapter 4 HBA Software Installation
Chapter 5 Known Issues
Appendix A HBA Specifications
Glossary
To Remove the HBA
  1. Prepare your operating system for HBA removal.
  2. Attach an antistatic wrist strap.
    See Observing ESD and Handling Precautions.
  3. Refer to the service manual for your specific system to locate the HBA in the chassis of the system.
  4. Remove the bracket screw that is securing the HBA to the chassis of the system and pull up gently and firmly to unseat the HBA from the PCIe slot.
  5. (Optional) If you need to replace the battery on the HBA, do the following:
    1. With a Phillips-head screwdriver, loosen the three screws that are securing the battery to the HBA.
    2. Place the screws aside and pull up on the battery to disconnect the battery connector from the HBA connector (JT3B1).
      See HBA Card Layout.
    3. Obtain the new battery and carefully press the battery onto the HBA to join the battery connector to the HBA connector (JT3B1).
    4. Secure the battery to the HBA by tightening the three screws from into the holes on the HBA.
    5. To reinstall the HBA into the system chassis, follow the instructions in To Install the HBA.
  6. Refer to the service manual for your specific system to reattach the cover to the system.
