Skip Navigation Links | |
Exit Print View | |
Sun Storage 6 Gb SAS PCIe RAID HBA, Internal Installation Guide For HBA Models SGX-SAS6-R-INT-Z and SG-SAS6-R-INT-Z |
Chapter 2 Hardware Installation and Removal
Observing ESD and Handling Precautions
To Prepare for Hardware Installation
To Connect the HBA to Internal Storage Devices
Chapter 3 Creating a Bootable Drive in a Preboot Environment
If you are using the Oracle Solaris OS, the installation is complete. You can obtain the latest patches for the Oracle Solaris OS at the system product web site.
If you are using a supported operating system other than the Oracle Solaris OS, install the HBA driver for your operating system, as described in HBA Software Installation.
