Skip Navigation Links | |
Exit Print View | |
SPARC SuperCluster T4-4 Zones With Oracle Database on Database Domains Configuration Guide |
Planning to Set Up Zones on Database Domains
Understanding Domain Configurations
Determining the Cores Available for Domains and Zones
Zones and Cluster Planning for Database Domains
Guidelines for Planning the Number of Zones and Clusters
Guidelines for Planning the Storage Server Disk Group Layout
Planning the Exadata Storage Server Disk Group Layout
Understanding an Example Scenario
Recording Your Existing and Planned Configuration Information
Recording Your Existing Configuration
Recording Your Zone Configuration Information
Recording Your Cluster Configuration Information
Recording Your Exadata Storage Server Disk Group Layout
Understanding Network Considerations
Understanding the Networking Setup Before Zone Creation
Host Management Network Before Zone Creation
InfiniBand Network Before Zone Creation
Understanding the Networking Setup After Zone Creation
Host Management Network After Zone Creation
Client Access Network After Zone Creation
InfiniBand Network After Zone Creation
Understanding the Network Setup for Clusters
Preparing to Configure Zones on Database Domains
Determine the Repository Location
Install or Update Packages From the Remote Repository
Install or Update Files From the Local Repository
Verify Configuration Tool Installation
Creating Configuration Files Using OEDA
Verify Exadata Storage Server Disk Space for Additional Zones
Creating Configuration Files Using OEDA: Manual Procedures
Oracle Exadata Deployment Assistant Overview
Complete the Customer Details Page
Complete the Hardware Selection Page
Complete the Define Customer Networks Page
Complete the Administration Network Page
Complete the Client Ethernet Network Page
Complete the Identify Compute Node OS and Enable Capacity-on-Demand Configuration Page
Review the Information in the Management and Private Networks Page
Complete the Define Clusters Page
Set Zone Default Configurations
Complete the Cluster Review and Edit SCAN, Client, VIP and Optional Backup Networks Page
Verify Remaining Configuration Information
Generate the Configuration Files
Creating Configuration Files Using OEDA: Automated Procedures
Locate the Necessary Files to Set Up Zones
Import the Most Recent OEDA Configuration File
Review Existing Configuration Information
Review the Information in the Identify Compute Node Operating System Page
Creating the Template Zone on Each Database Domain
Create a Template Zone on a Database Domain
Delete a Template Zone From a Database Domain
Determining if Additional VNETs Are Needed for a Database Domain
Determine if Additional VNETs Are Needed (CPU-to-Database Domain Mapping)
Determine if Additional VNETs Are Needed (Software Commands)
Set Up Public Key Authentication for ZFS Storage Controllers
Creating Additional Links on the IB Storage Network for Zones
Create Additional Links on the IB Storage Network for Zones
Access to the client access network is achieved through the dual-port 10-GbE network interface cards (NICs) installed in express module slots in each SPARC T4-4 server. There are four dual-port 10-GbE NICs in each SPARC T4-4 server. In each case, IPMP grouping is used to provide redundancy to the 10-GbE client access network, where two physical ports are part of one IPMP group and a single data address is used to access these two physical ports. For the situations where the two physical ports are on separate dual-port 10-GbE NICs, that data address allows traffic to continue flowing to the ports in the IPMP group, even if one of the two 10-GbE NICs fail.
The dual-port 10-GbE NICs, and the ports on each NIC, that are assigned to each domain will vary, depending on the number of domains on each SPARC T4-4 server:
One total domain – Two out of the four dual-port 10-GbE NICs are used in this situation, and one port from each dual-port 10-GbE NIC is part of one IPMP group for this domain:
Express module slot 2, port 0
Express module slot 14, port 1
Two total domains – Two of the four dual-port 10-GbE NICs are associated with each domain in this situation, and one port on each of the separate dual-port 10-GbE NICs would be part of one IPMP group for each domain:
First domain:
- Express module slot 2, port 0
- Express module slot 10, port 1
Second domain:
- Express module slot 6, port 0
- Express module slot 14, port 1
Three total domains – The number of dual-port 10-GbE NICs, and the ports used by each NIC, will vary for the three domains:
First domain: Two dual-port 10-GbE NICs are associated with this domain, and one port on each of the two NICs would be part of one IPMP group:
Second domain: One dual-port 10-GbE NIC is associated with this domain, and the two ports on the one NIC is part of one IPMP group:
- Express module slot 6, port 1
Third domain: One dual-port 10-GbE NIC is associated with this domain, and the two ports on the one NIC is part of one IPMP group:
- Express module slot 14, port 0
Four total domains – One dual-port 10-GbE NIC is associated with each domain in this situation, and the two ports on each NIC are part of one IPMP group:
First domain:
- Express module slot 2, port 1
Second domain:
- Express module slot 10, port 0
Third domain:
Fourth domain:
