Skip Navigation Links | |
Exit Print View | |
SPARC SuperCluster T4-4 Zones With Oracle Database on Database Domains Configuration Guide |
Planning to Set Up Zones on Database Domains
Understanding Domain Configurations
Determining the Cores Available for Domains and Zones
Zones and Cluster Planning for Database Domains
Guidelines for Planning the Number of Zones and Clusters
Guidelines for Planning the Storage Server Disk Group Layout
Determine the Available Existing Storage Capacity
Determine the Number of Clusters in the System and Maximum Amount of Space Available to Each Cluster
Determine the Amount of Space for Each Disk Group in Each Cluster
Understanding an Example Scenario
Recording Your Existing and Planned Configuration Information
Recording Your Existing Configuration
Recording Your Zone Configuration Information
Recording Your Cluster Configuration Information
Recording Your Exadata Storage Server Disk Group Layout
Understanding Network Considerations
Understanding the Networking Setup Before Zone Creation
Host Management Network Before Zone Creation
Client Access Network Before Zone Creation
InfiniBand Network Before Zone Creation
Understanding the Networking Setup After Zone Creation
Host Management Network After Zone Creation
Client Access Network After Zone Creation
InfiniBand Network After Zone Creation
Understanding the Network Setup for Clusters
Preparing to Configure Zones on Database Domains
Determine the Repository Location
Install or Update Packages From the Remote Repository
Install or Update Files From the Local Repository
Verify Configuration Tool Installation
Creating Configuration Files Using OEDA
Verify Exadata Storage Server Disk Space for Additional Zones
Creating Configuration Files Using OEDA: Manual Procedures
Oracle Exadata Deployment Assistant Overview
Complete the Customer Details Page
Complete the Hardware Selection Page
Complete the Define Customer Networks Page
Complete the Administration Network Page
Complete the Client Ethernet Network Page
Complete the Identify Compute Node OS and Enable Capacity-on-Demand Configuration Page
Review the Information in the Management and Private Networks Page
Complete the Define Clusters Page
Set Zone Default Configurations
Complete the Cluster Review and Edit SCAN, Client, VIP and Optional Backup Networks Page
Verify Remaining Configuration Information
Generate the Configuration Files
Creating Configuration Files Using OEDA: Automated Procedures
Locate the Necessary Files to Set Up Zones
Import the Most Recent OEDA Configuration File
Review Existing Configuration Information
Review the Information in the Identify Compute Node Operating System Page
Creating the Template Zone on Each Database Domain
Create a Template Zone on a Database Domain
Delete a Template Zone From a Database Domain
Determining if Additional VNETs Are Needed for a Database Domain
Determine if Additional VNETs Are Needed (CPU-to-Database Domain Mapping)
Determine if Additional VNETs Are Needed (Software Commands)
Set Up Public Key Authentication for ZFS Storage Controllers
Creating Additional Links on the IB Storage Network for Zones
Create Additional Links on the IB Storage Network for Zones
In general, follow this process to determine how to lay out your zones and clusters across the Exadata Storage Servers, where each decision point at the top of the process affects decisions made lower in the decision tree.
Determine the amount of existing usable disk space. How many Exadata Storage Servers are available for the clusters that you are creating? How much total usable disk space is available for those clusters?
Determine the number of clusters that you want for the zones that you are creating on the Database Domains. This, in conjunction with the total amount of existing usable disk space, is used to determine the maximum amount of space that will be available for each cluster.
Determine the amount of space to assign to each of the three disk groups in each cluster.
DATA
RECO
DBFS
Note - There is an option to designate the DBFS disk group set as UNUSED, if necessary.
Also determine the names to use for the disk groups for each cluster. For example, if you are creating disk groups for two clusters (ssc01r1 and ssc01r2), then you might use these names for the three disk groups for each cluster:
First cluster (ssc01r1):
- DATA_ssc01r1
- RECO_ssc01r1
- DBFS_ssc01r1
Second cluster (ssc01r2):
- DATA_ssc01r2
- RECO_ssc01r2
- DBFS_ssc01r2
Record your Exadata Storage Server disk group layout in the worksheet in Recording Your Exadata Storage Server Disk Group Layout.
The following topics provide more detailed information on each of these decisions points.
