You can have multiple ldmd configuration files with various names. The names are case-sensitive (for example, Alpha and alpha are different names), so configuration files that use the same word are allowed. The Oracle ILOM UI names are case-insensitive, but they are case-preserving. Thus, multiple configuration file names such as Alpha and alpha might cause errors in the Oracle ILOM UI.
For example, if you type the following command, the UI hangs if there are multiple configuration files present that use the same filename:
-> show /HOSTx/domain/configs
Workaround: Remove one of the case-matching ldmd configuration files. Then, wait for the Oracle ILOM infrastructure to auto-restart the UI process.
