These topics describe known issues with the server.
When You Create Logical Domains, Some Memory Is Reserved by the Server
sas2ircu Might Fail to Create a RAID Volume (BugID 15788910)
rKVMS Does Not Support Redirecting Storage From a SPARC Client (BugID 15795058)
Mouse Pointer Is Not Aligned With the Cursor in a Remote Window (BugID 15798251)
xhci Device Failed During Boot on USB Ports (BugID 15809582)
/System/Cooling Target Lists Power Supply Fans as Not Supported (BugID 15809846)
File Descriptor Leakage in libldom/ldom_xmpp_client.c (BugID 15811297)
High-speed PCIe I/O Cards Sometimes Downtrain to Gen1 I/O Speed (BugID 15825866)
Active mempm Should Balance Cage Assignment Across All Nodes (Bug ID15944881)
Drive OK to Remove LED Might Not Illuminate When a Drive is Unconfigured (BugID 16051551)
FPGA iPOST power-on-reset, error-reset, and hw-change Triggers Do Not Work (BugID 16192025)
CPU Power Management Can Lower Disk IOPS Performance (BugID 16355418, 17179054)
Oracle ILOM Sends V1 Authority, but Oracle Solaris Can Not Handle V1 Authority (BugID 16456603)
Management of SP Does Not Display a Table as Expected (BugID 16607793)
OPS Failing fault.ops.chassis.voltage.fail on FRU /SYS/MB at Component /SYS/MB (Bug ID 18070361)
POST Abort When Retiring Multiple Memory Pages (Bug ID 18091447)
RAID 10 Volumes Created Instead of RAID 1E on an Even Number of Target Disks (Bug ID 18335578)
Europa-Based 10 GbE PCIe Cards Generate Device Training Errors (Bug ID 18647589)
Processor Module Fault Results in Single Point of Failure (Bug ID 19439215)
