On a SPARC T5 system that has an SR-IOV configuration, you might experience a hang that cannot be stopped with the Ctrl-C command. The hang rarely occurs when you use the ldm unbind or ldm rm-io command.
Workaround: Reboot the instance of the Oracle Solaris OS that runs on the primary domain. Also, reboot any guest domains that share I/O resources with the primary domain.
