Go to main content
SPARC T5-4 Server Product Notes
Exit Print View
Updated: May 2016
Preinstalled Software
Software
Location
Description
Oracle Solaris 11.2 OS SRU 3.5
The OS is installed on drive 0, using a ZFS file system.
Host OS.
Oracle VM Server for SPARC
These software components are part of the Oracle Solaris 11 OS distribution.
/opt/SUNWldm
Manages logical domains.
Oracle VTS*
/usr/sunvts
Provides hardware validation tests.
The preinstalled OS is ready to be configured at the appropriate point when you first apply power to the server.
Mandatory package updates might not be preinstalled. Ensure that you obtain and install all mandatory updates before you put the server into production. See Mandatory Oracle Solaris 11 OS Package Updates.
Refer to the Oracle Solaris documentation for instructions on installing and configuring the Oracle Solaris OS.
You can reinstall the OS, along with mandatory package updates or patches, instead of using the preinstalled OS. See Minimum Supported Versions of the Firmware, OS, and Software.
