man pages section 3: Extended Library Functions, Volume 3
Exit Print View
Updated: July 2014
pool_walk_components(3POOL)
Name
pool_walk_components, pool_walk_pools, pool_walk_resources - walk objects within resource pool configurations
Synopsis
cc [ flag… ] file–lpool [ library… ]
#include <pool.h>
int pool_walk_components(pool_conf_t *conf,
     pool_resource_t *resource, void *arg,
     int (*callback)(pool_conf_t *, pool_component_t *, void *));
int pool_walk_pools(pool_conf_t *conf, void *arg,
     int (*callback)(pool_conf_t *, pool_t *, void *));
int pool_walk_resources(pool_conf_t *conf, pool_t *pool,
     void *arg, int (*callback)(pool_conf_t *,
     pool_resource_t *, void *));
Description
The walker functions provided with libpool(3LIB) visit each associated entity of the given type, and call the caller-provided callback function with a user-provided additional opaque argument. There is no implied order of visiting nodes in the walk. If the callback function returns a non-zero value at any of the nodes, the walk is terminated, and an error value of -1 returned. The conf argument for each function refers to the target configuration to which the operation applies.
The pool_walk_components() function invokes callback on all components contained in the resource.
The pool_walk_pools() function invokes callback on all pools defined in the configuration.
The pool_walk_resources() function invokes callback function on all resources associated with pool.
Return Values
Upon successful completion of the walk, these functions return 0. Otherwise -1 is returned and pool_error(3POOL) returns the pool-specific error value.
Errors
These functions will fail if:
POE_BADPARAM
The supplied configuration's status is not POF_VALID.
POE_INVALID_CONF
The configuration is invalid.
POE_SYSTEM
A system error has occurred. Check the system error code for more details.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
CSI
Enabled
Interface Stability
Uncommitted
MT-Level
Safe
See also
libpool(3LIB), pool_error(3POOL), attributes(5)
