man pages section 3: Extended Library Functions, Volume 3
Exit Print View
Updated: July 2014
ptree_create_and_add_prop(3PICLTREE)
Name
ptree_create_and_add_prop - create and add property to node and return property handle
Synopsis
cc [ flag... ] file... –lpicltree [ library... ]
#include <picltree.h>
int ptree_create_and_add_prop(picl_nodehdl_t nodeh,
     ptree_propinfo_t *infop, void *vbuf, picl_prophdl_t *proph);
Description
The ptree_create_and_add_prop() function creates a property using the property information specified in infop and the value buffer vbuf and adds the property to the node specified by nodeh. If proph is not NULL, the handle of the property added to the node is returned in proph.
Return Values
Upon successful completion, 0 is returned. On failure, a non-negative integer is returned to indicate an error.
PICL_STALEHANDLE is returned if the handle is no longer valid. This occurs if the PICL tree was refreshed or reinitialized.
PICL_INVALIDHANDLE is returned if the specified handle never existed.
Errors
PICL_NOTSUPPORTED
Property version not supported
PICL_VALUETOOBIG
Value exceeds maximum size
PICL_NOTPROP
Not a property
PICL_NOTTABLE
Not a table
PICL_PROPEXISTS
Property already exists
PICL_RESERVEDNAME
Property name is reserved
PICL_INVREFERENCE
Invalid reference property value
PICL_INVALIDHANDLE
Invalid handle
PICL_STALEHANDLE
Stale handle
PICL_FAILURE
General system failure
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
ptree_create_prop(3PICLTREE), ptree_add_prop(3PICLTREE), attributes(5)
