man pages section 3: Extended Library Functions, Volume 3
Exit Print View
Updated: July 2014
project_walk(3PROJECT)
Name
project_walk - visit active project IDs on current system
Synopsis
cc [ flag … ] file–lproject [ library … ]
#include <project.h>
int project_walk(int (*callback)(const projid_t project,
     void *walk_data), void *init_data);
Description
The project_walk() function provides a mechanism for the application author to examine all active projects on the current system. The callback function provided by the application is given the ID of an active project at each invocation and can use the walk_data to record its own state. The callback function should return non-zero if it encounters an error condition or attempts to terminate the walk prematurely; otherwise the callback function should return 0.
Return Values
Upon successful completion, project_walk() returns 0. It returns −1 if the callback function returned a non-zero value or if the walk encountered an error, in which case errno is set to indicate the error.
Errors
The project_walk() function will fail if:
ENOMEM
There is insufficient memory available to set up the initial data for the walk.
Other returned error values are presumably caused by the callback function.
Examples
Example 1 Count the number of projects available on the system.
The following example counts the number of projects available on the system.
#include <sys/types.h>
#include <stdio.h>
typedef struct wdata {
     uint_t count;
} wdata_t;
wdata_t total_count;
int
simple_callback(const projid_t p, void *pvt)
     wdata_t *w = (wdata_t *)pvt;
     w->count++;
     return (0);
total_count.count = 0;
errno = 0;
if ((n = project_walk(simple_callback, &total_count)) >= 0)
     (void) printf("count = %u\n", total_count.count);
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
getprojid(2), libproject(3LIB) , settaskid(2), attributes(5)
