man pages section 3: Curses Library Functions
Exit Print View
Updated: July 2014
box(3XCURSES)
Name
border, box, wborder - add a single-byte border to a window
Synopsis
cc [ flag... ] file... –I /usr/xpg4/include –L /usr/xpg4/lib \
–R /usr/xpg4/lib –lcurses [ library... ]
c89 [ flag... ] file... –lcurses [ library... ]
#include <curses.h>
int border(chtype ls, chtype rs, chtype ts, chtype bs, chtype tl,
     chtype tr, chtype bl, chtype br);
int wborder(WINDOW *win, chtype ls, chtype rs, chtype ts, chtype
bs,
     chtype tl,chtype tr, chtype bl, chtype br);
int box(WINDOW *win, chtype verch, chtype horch);
Description
The border() and wborder() functions draw a border around the specified window. All parameters must be single-byte characters whose rendition can be expressed using only constants beginning with ACS_. A parameter with the value of 0 is replaced by the default value.
Constant Values for Borders
Parameter
Default Constant
Default Character
verch
ACS_VLINE
horch
ACS_HLINE
ls
ACS_VLINE
rs
ACS_VLINE
ts
ACS_HLINE
bs
ACS_HLINE
bl
ACS_BLCORNER
br
ACS_BRCORNER
tl
ACS_ULCORNER
tr
ACS_URCORNER
The call
box(win,
verch, horch)
is a short form for
wborder(win,
verch, verch,
horch, horch, 0, 0, 0,
0)
When the window is boxed, the bottom and top rows and right and left columns overwrite existing text.
Parameters
ls
Is the character and rendition used for the left side of the border.
rs
Is the character and rendition used for the right side of the border.
ts
Is the character and rendition used for the top of the border.
bs
Is the character and rendition used for the bottom of the border.
tl
Is the character and rendition used for the top-left corner of the border.
tr
Is the character and rendition used for the top-right corner of the border.
bl
Is the character and rendition used for the bottom-left corner of the border.
br
Is the character and rendition used for the bottom-right corner of the border.
win
Is the pointer to the window in which the border or box is to be drawn.
verch
Is the character and rendition used for the left and right columns of the box.
horch
Is the character and rendition used for the top and bottom rows of the box.
Return Values
On success, these functions return OK. Otherwise, they return ERR.
Errors
None.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
Unsafe
Standard
See also
add_wch(3XCURSES), addch(3XCURSES), attr_get(3XCURSES), attroff(3XCURSES), border_set(3XCURSES), libcurses(3XCURSES), attributes(5), standards(5)
