man pages section 3: Curses Library Functions
Exit Print View
Updated: July 2014
mvaddwchnstr(3CURSES)
Name
curs_addwchstr, addwchstr, addwchnstr, waddwchstr, waddwchnstr, mvaddwchstr, mvaddwchnstr, mvwaddwchstr , mvwaddwchnstr - add string of wchar_t characters (and attributes) to a curses window
Synopsis
cc  [flag]... file... -lcurses [library]...
#include<curses.h>
int addwchstr(chtype *wchstr);
int addwchnstr(chtype *wchstr, int n);
int waddwchstr(WINDOW *win, chtype *wchstr);
int waddwchnstr(WINDOW *win, chtype *wchstr, int n);
int mvaddwchstr(int y, int x, chtype *wchstr);
int mvaddwchnstr(int y,  int x, chtype *wchstr, int n);
int mvwaddwchstr(WINDOW *win, int y, int x,  chtype *wchstr);
int mvwaddwchnstr(WINDOW *win, int y, int x , chtype *wchstr, int n);
Description
All of these routines copy wchstr, which points to a string of wchar_t characters, directly into the window image structure starting at the current cursor position. The four routines with n as the last argument copy at most n elements, but no more than will fit on the line. If n=−1 then the whole string is copied, to the maximum number that fit on the line.
The position of the window cursor is not advanced. These routines work faster than waddnwstr(3CURSES) because they merely copy wchstr into the window image structure. On the other hand, care must be taken when using these functions because they don't perform any kind of checking (such as for the newline character), they do not advance the current cursor position, and they truncate the string, rather than wrapping it around to the new line.
RETURN VALUE
RETURN VALUE
All routines return the integer ERR upon failure and an integer value other than ERR upon successful completion, unless otherwise noted in the preceding routine descriptions.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
MT-Level
Unsafe
See also
curses(3CURSES), waddnwstr(3CURSES), attributes(5)
Notes
The header file <curses.h> automatically includes the header files <stdio.h>, <unctrl.h> and <widec.h>.
Note that all routines except waddwchnstr() may be macros.
None of these routines can use the color attribute in chtype.
