man pages section 3: Curses Library Functions
Exit Print View
Updated: July 2014
inch(3XCURSES)
Name
inch, mvinch, mvwinch, winch - return a single-byte character (with rendition)
Synopsis
cc [ flag... ] file... –I /usr/xpg4/include –L /usr/xpg4/lib \
–R /usr/xpg4/lib –lcurses [ library... ]
c89 [ flag... ] file... –lcurses [ library... ]
#include <curses.h>
chtype inch(void);
chtype mvinch(int y, int x);
chtype mvwinch(WINDOW *win, int y, int x);
chtype winch(WINDOW *win);
Description
The inch() and winch() functions return the chtype character located at the current cursor position of the stdscr window and window win, respectively. The mvinch() and mvwinch() functions return the chtype character located at the position indicated by the x (column) and y (row) parameters (the former in the stdscr window; the latter in window win).
The complete character/attribute pair will be returned. The character or attributes can be extracted by performing a bitwise AND on the returned value, using the constants A_CHARTEXT, A_ATTRIBUTES, and A_COLOR.
Parameters
y
Is the y (row) coordinate of the position of the character to be returned.
x
Is the x (column) coordinate of the position of the character to be returned.
win
Is a pointer to the window that contains the character to be returned.
Return Values
On success, these functions return the specified character and rendition. Otherwise, they return ERR.
Errors
None.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
Unsafe
Standard
See also
addch(3XCURSES), attroff(3XCURSES), libcurses(3XCURSES), attributes(5), standards(5)
