man pages section 3: Curses Library Functions
Exit Print View
Updated: July 2014
menu_post(3CURSES)
Name
menu_post, post_menu, unpost_menu - write or erase menus from associated subwindows
Synopsis
cc [ flag... ] file... –lmenu –lcurses [ library... ]
#include <menu.h>
int post_menu(MENU *menu);
int unpost_menu(MENU *menu);
Description
post_menu() writes menu to the subwindow. The application programmer must use curses library routines to display the menu on the physical screen or call update_panels() if the panels library is being used.
unpost_menu() erases menu from its associated subwindow.
Return Values
These routines return one of the following:
E_OK
The routine returned successfully.
E_SYSTEM_ERROR
System error.
E_BAD_ARGUMENT
An incorrect argument was passed to the routine.
E_POSTED
The menu is already posted.
E_BAD_STATE
The routine was called from an initialization or termination function.
E_NO_ROOM
The menu does not fit within its subwindow.
E_NOT_POSTED
The menu has not been posted.
E_NOT_CONNECTED
No items are connected to the menu.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
MT-Level
Unsafe
See also
curses(3CURSES), menus(3CURSES), panels(3CURSES), attributes(5)
Notes
The header <menu.h> automatically includes the headers <eti.h> and <curses.h>.
