man pages section 3: Curses Library Functions
Exit Print View
Updated: July 2014
flash(3CURSES)
Name
curs_beep, beep, flash - curses bell and screen flash routines
Synopsis
cc [ flag ... ] file ... –lcurses [ library ... ]
#include <curses.h>
int beep(void);
int flash(void);
Description
The beep() and flash() routines are used to signal the terminal user. The routine beep() sounds the audible alarm on the terminal, if possible; if that is not possible, it flashes the screen (visible bell), if that is possible. The routine flash() flashes the screen, and if that is not possible, sounds the audible signal. If neither signal is possible, nothing happens. Nearly all terminals have an audible signal (bell or beep), but only some can flash the screen.
Return Values
These routines always return OK.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
MT-Level
Unsafe
See also
curses(3CURSES), attributes(5)
Notes
The header <curses.h> automatically includes the headers <stdio.h> and <unctrl.h>.
