Skip Navigation Links
Exit Print View
Oracle Switch ES1-24 Documentation
search filter icon
search icon
Document Information
Using This Documention
Product Notes
Related Documentation
CLI Command Modes
Feedback
Support and Accessibility
Installation
Understanding the Installation
Installation Task Overview
Front Panel Components
Rear Panel Components
Confirming Specifications
Physical Specifications
Electrical Specifications
Environmental Specifications
Understanding Cabling
Understanding Management and Power Cabling
Understanding Data Cabling
Single-Switch Location Guidelines
Preparing for Installation
ESD Precautions
Tools Needed for Installation
Verify Switch Kit Contents
Verify Rack Rail Kit Contents
Assemble an SFP+ Data Cable
Route Cables
Installing the Switch
Assemble a Filler
Attach the Rails to the Switch
Attach Telco Adapters to the Rack Slides
Attach the Rack Slides to the Rack
Install the Switch Into the Rack
Attach Power Cords
Install the Air Duct and Front Support
Attach Data and Management Cables
Prepare the Front Support and Small Air Duct
Powering On the Switch
Power On the Switch
Oracle ILOM Overview
Verify the DHCP-Assigned IP Address and Host Name
Configure Network Management From the CLI (SER MGT)
Log Into the Oracle ILOM Web (NET MGT)
Log Into the Oracle ILOM CLI (NET MGT)
Log Into the Oracle ILOM CLI (SER MGT)
Configuration
Administering the Switch
Log In to the Oracle ILOM CLI
Create a SEFOS User
Change a SEFOS User Privilege Level
Configure Network Management From the Web Interface
Log Out of the Oracle ILOM CLI
Update the Firmware
Administering SEFOS
SEFOS Setup Tasks
Understanding SEFOS Basics
Configuring the SEFOS Environment
Managing Configuration Files
Managing Log Files
Configuring the Switching Feature
Switching Feature Topology
Configure Initial Settings
Verify the Configuration
Configure VLAN Forwarding
Verify VLAN Membership
Configure RSTP
Configure LA
Save a Configuration
Configuring the Routing Feature
Routing Feature Topology
Configuring Static Routing
Configuring Dynamic Routing
Disabling Routing
Service
Detecting and Managing Faults
Front Panel LEDs
Rear Panel LEDs
Check Switch Status (LEDs)
Sensors Overview
Check Switch Status (Oracle ILOM)
Component Sensor Targets
Motherboard Sensor Targets
Preparing for Service
ESD Precautions
Tools Needed for Service
Replaceable Components
Remove the Front Support and Air Duct
Remove the CMA
Install the CMA
Servicing Power Supplies
Power Off a Power Supply
Remove a Power Supply
Install a Power Supply
Power On a Power Supply
Servicing the Fan Module
Remove the Fan Module
Install the Fan Module
Glossary
Index
Note - The rack slides might have a telco adaptor attached, and so would look different than those in these illustrations. However, the procedure to attach the rack slides is the same.
  1. Identify the prerequisite and subsequent installation tasks that you must perform in conjunction with this procedure.
    See Installation Task Overview.
  2. Gather these components.
    • Rack slide assembly (2)
    • CMA assembly
    • M6 cage nuts (12)
    • M6x14 mm Philips screws (10)
    See Verify Rack Rail Kit Contents.
  3. Install the cage nuts to the inside of the rack posts where the rack slide assemblies are to install.
    Note - On the hot aisle, install three cage nuts on each post. On the cold aisle, install two cage nuts on each post for telco racks, or three cage nuts on each post for any other rack
    image:Figure shows attaching the cage nut to the rack post.
  4. Orient a rack slide assembly with the rectangular hole at one end toward the cold aisle.
    The green tab is toward the hot aisle.
    image:Figure shows installing the rack slide assemblies.
  5. Using a No. 2 Philips screwdriver, secure the rack slide assembly to the rack with four M6x14 screws.
  6. Repeat Step 4 and Step 5 for the other rack slide assembly.
  7. Attach the CMA assembly to the hot aisle end of the rack slide assemblies with two M6x14 screws.
    image:Figure shows attaching the CMA to the rack slide assemblies.
  8. Install the switch into the rack.
    See Install the Switch Into the Rack.
Related Information
