Skip Navigation Links
Exit Print View
Oracle Switch ES1-24 Documentation
search filter icon
search icon
Document Information
Using This Documention
Product Notes
Related Documentation
CLI Command Modes
Feedback
Support and Accessibility
Installation
Understanding the Installation
Installation Task Overview
Front Panel Components
Rear Panel Components
Confirming Specifications
Physical Specifications
Electrical Specifications
Environmental Specifications
Understanding Cabling
Understanding Management and Power Cabling
Understanding Data Cabling
Single-Switch Location Guidelines
Preparing for Installation
ESD Precautions
Tools Needed for Installation
Verify Switch Kit Contents
Verify Rack Rail Kit Contents
Assemble an SFP+ Data Cable
Route Cables
Installing the Switch
Assemble a Filler
Attach the Rails to the Switch
Attach Telco Adapters to the Rack Slides
Attach the Rack Slides to the Rack
Install the Switch Into the Rack
Attach Power Cords
Install the Air Duct and Front Support
Attach Data and Management Cables
Prepare the Front Support and Small Air Duct
Powering On the Switch
Power On the Switch
Oracle ILOM Overview
Verify the DHCP-Assigned IP Address and Host Name
Configure Network Management From the CLI (SER MGT)
Log Into the Oracle ILOM Web (NET MGT)
Log Into the Oracle ILOM CLI (NET MGT)
Log Into the Oracle ILOM CLI (SER MGT)
Configuration
Administering the Switch
Log In to the Oracle ILOM CLI
Create a SEFOS User
Change a SEFOS User Privilege Level
Configure Network Management From the Web Interface
Log Out of the Oracle ILOM CLI
Update the Firmware
Administering SEFOS
SEFOS Setup Tasks
Understanding SEFOS Basics
Configuring the SEFOS Environment
Managing Configuration Files
Managing Log Files
Configuring the Switching Feature
Switching Feature Topology
Configure Initial Settings
Verify the Configuration
Configure VLAN Forwarding
Verify VLAN Membership
Configure RSTP
Configure LA
Save a Configuration
Configuring the Routing Feature
Routing Feature Topology
Configuring Static Routing
Configuring Dynamic Routing
Disabling Routing
Service
Detecting and Managing Faults
Front Panel LEDs
Rear Panel LEDs
Check Switch Status (LEDs)
Sensors Overview
Check Switch Status (Oracle ILOM)
Component Sensor Targets
Motherboard Sensor Targets
Preparing for Service
ESD Precautions
Tools Needed for Service
Replaceable Components
Remove the Front Support and Air Duct
Remove the CMA
Install the CMA
Servicing Power Supplies
Power Off a Power Supply
Remove a Power Supply
Install a Power Supply
Power On a Power Supply
Servicing the Fan Module
Remove the Fan Module
Install the Fan Module
Glossary
Index
Configure RSTP
This task shows the traffic flow in the RSTP configuration on SEFOS running on the switch targets. This task verifies whether a loop is present in the topology, if it is detected, and if the traffic is blocked for the alternate port.
See Switching Feature Topology for the topology of this task.
  1. Configure the initial settings.
    See Configure Initial Settings.
  2. Configure VLAN forwarding in SEFOS-1 and SEFOS-2.
    See Configure VLAN Forwarding.
  3. On SEFOS-1, verify the port status in RSTP mode.
    SEFOS-1# show spanning-tree
    Root Id          Priority   32768
                     Address    00:14:4f:6c:63:0f
                     Cost       0
                     Port       0 [0]
                     Max Age 20 Sec, Forward Delay 15 Sec
    Spanning tree Protocol Enabled.
    Bridge is executing the rstp compatible Rapid Spanning Tree Protocol
    Bridge Id        Priority 32768
                       Cost       0
                       Port       0 [0]
                       Hello Time 2 sec, Max Age 20 sec, Forward Delay 15 sec
                       Dynamic Path Cost is Disabled
                       Dynamic Path Cost Lag-Speed Change is Disabled
    Name              Role         State        Cost     Prio   Type
    Ex0/1                    Designated      Forwarding   2000     128      P2P
    Ex0/2                    Designated      Forwarding   2000     128      P2P
    Ex0/21                   Designated      Forwarding   2000     128      P2P
    Ex0/22                   Designated      Forwarding   2000     128      P2P
  4. On SEFOS-2, verify the port status in RSTP mode.
    SEFOS-2# show spanning-tree
                    Cost       4000
                    Port       Ex0/1
                    Address 00:14:4f:6c:6e:0e
    Ex0/21                   root                Forwarding   2000     128      P2P
    Ex0/22                   Alternate    Discarding   2000     128     P2P
  5. Ping from host A to host C.
    # ping -s 20.0.0.30
    Traffic is forwarded through the extreme-ethernet 0/21 port on SEFOS-1 to SEFOS-2 port 21.
  6. Shut down the extreme-ethernet 0/21 port from SEFOS-2 and verify the port status.
    SEFOS-2# configure terminal
    SEFOS-2(config)# int ext 0/21
    SEFOS-2(config)# shut
    SEFOS-2(config)# exit
                    Address    00:14:4f:6c:69:0f
                    Cost       4000
                    Port       Ex0/1
    Ex0/21            Disabled     Forwarding   2000     128    P2P
    Ex0/22            root         Forwarding   2000     128    P2P
  7. Ping from host A to host C.
    # ping 20.0.0.30
    Traffic should be forwarded through the extreme-ethernet 0/18 port on SEFOS-1. If RSTP is working, there will be a change in the port state.
Related Information
