Go to main content
Oracle® Exadata Storage Server X5-2 High Capacity Service Manual
Exit Print View
Updated: January 2018
Configure I/O Resource Allocation
  1. Access the BIOS Setup Utility menus.
    See Access BIOS Setup Utility Menus.
  2. In the BIOS Setup Utility menus, navigate to the IO Menu.
    The IO Menu screen appears.
  3. Select Add In Cards and press Enter to display the add-in card slots.
  4. Select the slot for which you want to configure the card, and press Enter.
  5. Do one of the following:
    • Select Enabled to enable I/O resource allocation for the I/O card.
    • Select Disabled to disable I/O resource allocation for the I/O card.
  6. Press the F10 key to save the changes and exit the BIOS Setup Utility.
Related Information
