Go to main content
Oracle® Exadata Storage Server X5-2 High Capacity Service Manual
Exit Print View
Updated: January 2018
Configure Option ROM Settings
  1. Access the BIOS Setup Utility menus.
    See Access BIOS Setup Utility Menus.
  2. In the BIOS Setup Utility menus, navigate to the IO Menu.
    The IO Menu screen appears.
    image:This figure shows the IO Menu screen.
  3. In the IO Menu, select either Internal Devices or Add In Cards and press Enter to display the internal device or add-in card slot for which you want to enable or disable Option ROM.
    The Internal Devices or Add In Cards screen appears.
    image:This figure shows the BIOS Option ROM settings within the IO                         Menu.
  4. Select the internal device or add In card slot that you want to configure.
    The Option ROM screen for that internal device or add-in card slot appears.
  5. Select OpROM Enable and press Enter. Do one of the following:
    • Select Enabled to enable the Option ROM setting.
    • Select Disabled to disable the Option ROM setting.
  6. Press the F10 key to save the changes and exit the BIOS Setup Utility.
Related Information
