Go to main content
Oracle® Exadata Storage Server X5-2 High Capacity Service Manual
Exit Print View
Updated: January 2018
Servicing the Battery
The real-time clock (RTC) battery maintains system time when the server is powered off and a time server is unavailable. If the server fails to maintain the proper time when the system is powered off and not connected to a network, replace the battery.
Caution
Caution  -  Ensure that all power is removed from the server before removing or installing the battery. You must disconnect the power cables from the system before performing this procedure.
This section covers the following topics:
