Go to main content
Oracle® Exadata Storage Server X5-2 High Capacity Service Manual
Exit Print View
Updated: January 2018
Install a Fan Module
  1. Remove the replacement fan module from its packaging, and place it on an antistatic mat.
  2. With the top cover fan assembly door open, install the replacement fan module into the server [1].
    The fan modules are keyed to ensure that they are installed in the correct orientation.
    image:Figure showing how to install a fan module.
  3. Press down on the fan module and apply firm pressure to fully seat the fan module.
  4. Verify that the fan module status LED on the replacement fan module is lit green.
  5. Using your thumb and forefinger, tighten the captive screw to secure the fan module to the chassis. Then use a No. 2 Phillips screwdriver to tighten the screw an additional 1/4 turn to secure the fan module to the chassis [2].
  6. Close the top cover fan assembly door.
  7. Verify that the Top Fan Fault LED on the front of the server and the Service Required LEDs on the front and rear of the server are extinguished.
    See Server System-Level Status Indicators for more information about identifying and interpreting system status indicators.
  8. Consider your next step:
    • If you installed the fan module as part of another procedure, return to that procedure.
    • Otherwise, return the server to operation. See Returning the Server to Operation.
Related Information
