Go to main content
Oracle® Exadata Storage Server X5-2 High Capacity Service Manual
Exit Print View
Updated: January 2018
Storage Drives Hot-Plug Conditions
The hard disk drives (HDDs) in the server are hot-pluggable, but this capability depends on how the drives are configured. To hot-plug a drive you must be able to take the drive offline before you can remove it. When you take the drive offline, you prevent any application from accessing the drive and remove the logical software links to the drive.
Note -  Replacing a drive does not require removing the server from a rack.
Related Information
