Table 40. SiebelBusComp Methods Syntax Summary
ActivateField Method |
Allows queries to retrieve data for the specified field. |
boolean activateField(String fieldName) throws SiebelException
ActivateMultipleFields Method |
Allows queries to retrieve data for the fields specified in the property set. |
boolean activateMultipleFields(SiebelPropertySet psFields) throws SiebelException
Associate Method |
Creates a new many-to-many relationship for the parent object through an association business component. |
boolean associate(boolean isInsertBefore) throws SiebelException
BusObject Method |
Returns the business object that contains the business component. |
SiebelBusObject busObject() throws SiebelException
ClearToQuery Method |
Clears the current query and sort specifications on the business component. |
boolean clearToQuery() throws SiebelException
DeactivateFields Method |
Deactivates every currently activated field. |
boolean deactivateFields()
DeleteRecord Method |
Removes the current record from the business component. |
boolean deleteRecord() throws SiebelException
ExecuteQuery Method |
Retrieves a set of BusComp records. |
boolean executeQuery(boolean cursorMode) throws SiebelException
ExecuteQuery2 Method |
boolean executeQuery2(boolean cursorMode, boolean ignoreMaxCursorSize) throws SiebelException
FirstRecord Method |
Moves to the first record in the business component. |
boolean firstRecord() throws SiebelException
GetFieldValue Method |
Returns a value for the field specified in the argument. |
String getFieldValue(String fieldName) throws SiebelException
GetFormattedFieldValue Method |
Returns a formatted value for the field specified in the argument. |
String getFormattedFieldValue(String fieldName) throws SiebelException
GetMultipleFieldValues Method |
Returns values for the fields specified in the property set. |
boolean getMultipleFieldValues(SiebelPropertySet Src, SiebelPropertySet result) throws SiebelException
GetMVGBusComp Method |
Returns the MVG business component associated with the field specified in the argument. |
SiebelBusComp getMVGBusComp(String fieldName) throws SiebelException
GetNamedSearch Method |
Returns the argument-named search specification. |
String getNamedSearch(String searchName) throws SiebelException
GetPicklistBusComp Method |
Returns the pick business component associated with the field specified in the argument. |
SiebelBusComp getPicklistBusComp(String fieldName) throws SiebelException
GetSearchExpr Method |
Returns the current search expression. |
String getSearchExpr() throws SiebelException
GetSearchSpec Method |
Returns the current search specification for the field specified in the argument. |
String getSearchSpec(String fieldName) throws SiebelException
GetUserProperty Method |
Returns the value for the specified property. |
String getUserProperty(String property) throws SiebelException
GetViewMode Method |
Returns the visibility mode for the business component. |
int getViewMode()
InvokeMethod Method |
Calls the specialized method named in the argument. |
String invokeMethod(String methodName, String[] methodArgs) throws SiebelException
LastRecord Method |
Moves to the last record in the business component. |
boolean lastRecord() throws SiebelException
Name Method |
Returns the name of the business component. |
String name()
NewRecord Method |
Adds a new record to the business component. |
boolean newRecord(boolean isInsertBefore) throws SiebelException
NextRecord Method |
Moves to the next record in the business component. |
boolean nextRecord() throws SiebelException
ParentBusComp Method |
Returns the parent business component. |
SiebelBusComp parentBusComp() throws SiebelException
Pick Method |
Places the currently selected record in a picklist business component into the appropriate fields of the parent business component. |
boolean pick() throws SiebelException
PreviousRecord Method |
Moves to the previous record in the business component. |
boolean previousRecord() throws SiebelException
RefineQuery Method |
Refines a query after a query has been executed. |
boolean refineQuery() throws SiebelException
Release Method |
Enables the release of the business component and its resources on the Siebel Server. |
void release()
SetFieldValue Method |
Assigns a new value to the named field for the current row of the business component. |
boolean setFieldValue(String fieldName, String fieldValue) throws SiebelException
SetFormattedFieldValue Method |
Accepts the field value in the current local format and assigns the new value to the named field for the current row of the business component. |
boolean setFormattedFieldValue(String fieldName, String fieldValue) throws SiebelException
SetMultipleFieldValues Method |
Assigns new values to the multiple fields specified in the property set for the current row of the business component. |
boolean setMultipleFieldValues(SiebelPropertySet psFields) throws SiebelException
SetNamedSearch Method |
Sets a named search specification on the business component. |
boolean setNamedSearch(String searchName, String searchText) throws SiebelException
SetSearchExpr Method |
Sets an entire search expression on the business component. |
boolean setSearchExpr(String searchExpr) throws SiebelException
SetSearchSpec Method |
Sets the search specification for the specified field. |
boolean setSearchSpec(String fieldName, String searchSpec) throws SiebelException
SetSortSpec Method |
Sets the sort specification for a query. |
boolean setSortSpec(String sortSpec) throws SiebelException
SetUserProperty Method |
Sets the value of the specified User Property. |
boolean setUserProperty(String propName, String propVal)
SetViewMode Method |
Sets the visibility type for the business component. |
boolean setViewMode(int mode) throws SiebelException
UndoRecord Method |
Reverses any uncommitted changes made to the record. |
boolean undoRecord() throws SiebelException
WriteRecord Method |
Commits to the database any changes made to the current record. |
boolean writeRecord() throws SiebelException
