Siebel Hospitality Guide > Working with Inventory > Checking Inventory Availability Using Property Screen Views > Reviewing SR Type AvailabilityThe SR Type Availability view shows the availability information for a given sleeping room type at a particular property. The availability numbers are displayed by room type and date. When the user navigates to this view, the user sees the sleeping room availability for the current date as well as for the next seven days. The user can query for different sleeping room types and date combinations to display different availability numbers. The user can also navigate to the Property SR Type Availability view by clicking the Room Type field in any Room Block Line item record in the Quotes Room Blocks view. Using this method, the user navigates to the SR Type Availability view and sees availability information beginning with the date assigned to the Room Block Line Item record. This task is a step in Process of Working with Event Inventory. |
| Siebel Hospitality Guide |
