Siebel Hospitality Guide > Working with Inventory > Checking Inventory Availability Using Property Screen Views > Reviewing Transient, Group, and Total AvailabilityThe sales representative, event execution user, and the revenue manager can use the Property Total Availability view to gain a better understanding of the total sleeping room availability information for a property. The Total Availability view contains four read-only sections. The Property form provides high-level information about the property in the Key Property Information, Property Classification, Capacity Information, Systems Information, Units Information, and Rating Information sections. Under the property form, three lists display availability figures by total group, total transient and total availability. By default, all three lists show availability counts, by type, starting with the current date across a seven-day period. The user can query for a different start date, which is displayed synchronously across the three lists. The Total Transient Availability list shows the number of transient sleeping rooms available for a particular property. The numbers are broken down further into types that include: Transient availability information is typically populated by system integrators. The Property Total Group Availability list is identical to the list that appears in the Property screen's Total Group Availability view. The Total Availability list shows the sum total of the transient and group information. It provides a snapshot view of the total number of available sleeping rooms. Table 9 describes the information that appears in the rows in the Total Availability list. The Special Dates button allows users to obtain information about any special dates or sell notes for the property that correspond to the date range that is being displayed for inventory. The user can also navigate to the Property Total Availability view by clicking the link in the Date field of any Room Block Line Item record. The Total Availability view appears showing a start date that corresponds to the date assigned to the Room Block Line item record. This task is a step in Process of Working with Event Inventory. |
| Siebel Hospitality Guide |
