| Skip Navigation Links | |
| Exit Print View | |
Sun Storage 6 Gb SAS PCIe RAID HBA, Internal Installation Guide For HBA Models SGX-SAS6-R-INT-Z and SG-SAS6-R-INT-Z |
Chapter 2 Hardware Installation and Removal
Chapter 3 Creating a Bootable Drive in a Preboot Environment
Overview of Creating a Bootable Drive in a Preboot Environment
Methods For Creating a Bootable Drive
Creating a Bootable Drive (SPARC)
To Create a Bootable Drive (SPARC)
Importing an Existing Logical Drive Configuration (SPARC)
To Import an Existing Logical Drive Configuration From a Different Controller (SPARC)
Creating an Alias for a Bootable Drive (SPARC)
To Create an Alias for a Bootable Drive (SPARC)
Creating a Bootable Drive (x86)
To Create a Bootable Drive (x86)
Using the Configuration Options Menu to Create a Bootable Logical Drive (x86)
To Verify the Drives and Their Slots (x86)
To Create a Logical Drive (x86)
To Confirm the Logical Drive Creation (x86)
Using the pcli Utility to Create a Bootable Drive (x86)
To Create a Logical Drive With the pcli Utility (x86)
Importing an Existing Logical Drive Configuration (x86)
To Import an Existing Logical Drive Configuration Using the Configuration Options Menu (x86)
To Import an Existing Logical Drive Configuration in Legacy Booting Mode (x86)
To Boot an x86 Server From an External Disk Drive
Validating the Label of the HBA Logical Drive
To Verify That the Label of a Logical Drive Is Valid
Installing the Oracle Solaris OS
To Prepare to Install the Oracle Solaris OS
To Install the Oracle Solaris OS
This section describes how to use the pcli utility to create a logical drive on a SPARC system prior to installing the Oracle Solaris operating system (OS). This section contains the following topics:
pcli commands can produce large amounts of detailed output. The xterm and gnome terminal windows provide scroll bar functionality, which helps with viewing such output.
{0} ok show-devs
/pci@1e,600000/pci@0/pci@3/LSI,mrsas@0
/pci@1e,600000/pci@0/pci@3/LSI,mrsas@0/disk
/pci@1e,600000/pci@0/pci@3/LSI,mrsas@1
{0} ok “ /pci@1e,600000/pci@0/pci@3/LSI,mrsas@0” select-dev
You have now selected the HBA upon which all pcli commands will operate. This means you do not need to specify the HBA in any pcli command that you issue, unlike with the MegaCli utility. For example, if you issue the pcli command, -AdpAllInfo, the command automatically applies to the selected HBA. However, the equivalent command through the MegaCli utility would apply only to the card that you specify (the 0 card, as shown here):
SPARC pcli: {0} ok cli -AdpAllInfo
MegaCli: MegaCli -AdpAllInfo -a0
Product Name : LSI MegaRAID SAS 9261-8i
Product Name : LSI MegaRAID SAS 9280-8e
The -AdpAllInfo command provides the product name of the HBA. The 8i at the end of the HBA name, LSI MegaRAID SAS 9261-8i, indicates the card is an internal card. If the card is external, the name ends with 8e.
You are now ready to use the pcli commands to create a logical drive, or MegaRAID virtual drive, on the HBA.
Drives attached directly to the HBA are assigned an Enclosure Device ID number of 252 (only eight physical drives can be attached in this way). Drives connected to the HBA through a SAS expander or an external enclosure are assigned different Enclosure Device ID values. In the following example, the physical drive listed in the output is attached directly to the HBA (Enclosure Device ID value of 252).
{0} ok cli -PdList
Adapter #0
Enclosure Device ID: 252
Slot Number: 0
{0} ok cli -CfgLdAdd -r0[252:0] -- for RAID 0, with Enclosure #252 and Slot 0 --
{0} ok cli -CfgLdAdd -r1[E0:S0,E1:S1] -- for RAID 1 --
All disks used by the HBA must be labeled, or contain a volume table of contents (VTOC). If you attempt to use an unlabeled disk with the HBA, the disk might not be recognized by the OS or the OS installation itself might fail. For more information about labeling disks, see the documentation for the physical disks.
