Skip Navigation Links | |
Exit Print View | |
Sun Ethernet Fabric Operating System VLAN Administration Guide |
Configuring Static VLAN Entries
Retrieve the Configuration Details for all of the VLANs on a Switch
Retrieve the Configuration Details of a particular VLAN on the Switch
Configure a Static Unicast Entry
Configure a Static Multicast Entry
Configure Dynamic VLAN Learning
Configure Dynamic Multicast Learning
Configure Restricted VLAN Registration
Configure Restricted Group Registration
Configuring Service Classes and Expedited Traffic
Map a Priority to Traffic Class
Configure the Acceptable Frame Type
Configuring Static Unicast and Multicast Entries
Configure Static Unicast Entry in Topology 1
Configure Static Unicast Entry in Topology 2
Configure VLANs on the Nonroot Bridge
To configure restricted group registration, you must ensure that the following prerequisites are met:
Interface P3 in switch 1 and switch 2 must be enabled.
Static multicast entry must be configured.
Restricted VLAN registration must be configured.
See Default Settings for the topology for this procedure.
SEFOS# configure terminal SEFOS(config)# interface extreme-ethernet 0/3 SEFOS(config-if)# no shutdown SEFOS(config-if)# exit SEFOS(config)# interface extreme-ethernet 0/4 SEFOS(config-if)# no shutdown SEFOS(config-if)# exit SEFOS(config)# vlan 2 SEFOS(config-vlan)# ports extreme-ethernet 0/3-4 SEFOS(config-vlan)# exit SEFOS(config)# mac-address-table static multicast 01:02:03:04:05:06 vlan 2 interface extreme-ethernet 0/3 SEFOS(config)# end
SEFOS# configure terminal SEFOS(config)# interface extreme-ethernet 0/3 SEFOS(config-if)# group restricted enable SEFOS(config-if)# end
SEFOS# show vlan port config port extreme-ethernet 0/3 Vlan Port configuration table -------------------------------------- Port Ex0/2 Port Vlan ID : 1 Port Acceptable Frame Type : Admit All Port Ingress Filtering : Disabled Port Mode : Hybrid Port Gvrp Status : Enabled Port Gmrp Status : Enabled Port Gvrp Failed Registrations : 0 Gvrp last pdu origin : 00:01:02:03:04:02 Port Restricted Vlan Registration : Disabled Port Restricted Group Registration : Enabled Mac Based Support : Disabled Subnet Based Support : Disabled Port-and-Protocol Based Support : Enabled Default Priority : 0 Dot1x Protocol Tunnel Status : Peer LACP Protocol Tunnel Status : Peer Spanning Tree Tunnel Status : Peer GVRP Protocol Tunnel Status : Peer GMRP Protocol Tunnel Status : Peer IGMP Protocol Tunnel Status : Peer Filtering Utility Criteria : Default Port Protected Status : Disabled --------------------------------------------------------------
SEFOS# show mac-address-table Vlan Mac Address Type Ports ------- --------------- ------- ------- 1 00:1b:21:53:71:f9 Learnt Ex0/16 1 00:21:28:56:d7:ab Learnt Ex0/3 1 00:21:28:56:d7:ac Learnt Ex0/4 Total Mac Addresses displayed: 3
Note - The group entry (01:02:03:04:05:06) is not present in switch 2.
