Skip Navigation Links | |
Exit Print View | |
Sun Ethernet Fabric Operating System VLAN Administration Guide |
Configuring Static VLAN Entries
Retrieve the Configuration Details for all of the VLANs on a Switch
Retrieve the Configuration Details of a particular VLAN on the Switch
Configure a Static Unicast Entry
Configure a Static Multicast Entry
Configure Dynamic VLAN Learning
Configure Dynamic Multicast Learning
Configure Restricted VLAN Registration
Configure Restricted Group Registration
Configuring Service Classes and Expedited Traffic
Map a Priority to Traffic Class
Configure the Acceptable Frame Type
Configuring Static Unicast and Multicast Entries
Configure Static Unicast Entry in Topology 1
Configure Static Unicast Entry in Topology 2
Configure VLANs on the Nonroot Bridge
For this configuration, you must ensure that the following prerequisites are met:
Interface P2 in switch 1 and switch 2 must be enabled.
VLAN must be configured.
See Example Topolgy 1 for the topology referenced this procedure.
SEFOS# configure terminal SEFOS(config)# interface extreme-ethernet 0/15 SEFOS(config-if)# no shutdown SEFOS(config-if)# exit SEFOS(config)# vlan 2 SEFOS(config-VLAN)# ports extreme-ethernet 0/15,0/3 SEFOS(config-VLAN)# exit SEFOS(config)# interface extreme-ethernet 0/3 SEFOS(config-if)# no shutdown SEFOS(config-VLAN)# exit
SEFOS# configure terminal SEFOS(config)# interface extreme-ethernet 0/3 SEFOS(config-if)# no shutdown SEFOS(config-if)# exit
SEFOS# show vlan id 2 Vlan database ------------------- Vlan ID : 2 Member Ports : Ex0/3, Ex0/15 Untagged Ports : None Forbidden Ports : None Name : Status : Permanent --------------------------------------
SEFOS# show vlan id 2 Vlan database ------------------- Vlan ID : 2 Member Ports : Ex0/3 Untagged Ports : None Forbidden Ports : None Name : Status : Dynamic Gvrp ---------------------------------------
