Skip Navigation Links | |
Exit Print View | |
Sun Ethernet Fabric Operating System VLAN Administration Guide |
Configuring Static VLAN Entries
Retrieve the Configuration Details for all of the VLANs on a Switch
Retrieve the Configuration Details of a particular VLAN on the Switch
Configure a Static Unicast Entry
Configure a Static Multicast Entry
Configure Dynamic VLAN Learning
Configure Dynamic Multicast Learning
Configure Restricted VLAN Registration
Configure Restricted Group Registration
Configuring Service Classes and Expedited Traffic
Map a Priority to Traffic Class
Configure the Acceptable Frame Type
Configuring Static Unicast and Multicast Entries
Configure Static Unicast Entry in Topology 1
Configure Static Unicast Entry in Topology 2
The same configuration guidelines apply for VLANs on nonroot bridges (switch 1) as they do on the root bridge (switch 2).
SEFOS# configure terminal SEFOS(config)# vlan 2 SEFOS(config-vlan)# ports extreme-ethernet 0/3 SEFOS(config-vlan)# exit SEFOS(config)# exit
SEFOS# show vlan Vlan database ------------- Vlan ID : 1 Member Ports : Ex0/1, Ex0/2, Ex0/3, Ex0/4, Ex0/5, Ex0/6 Ex0/7, Ex0/8, ... Untagged Ports : Ex0/1, Ex0/2, Ex0/3, Ex0/4, Ex0/5, Ex0/6 Ex0/7, Ex0/8, ... Forbidden Ports : None Name : Status : Permanent ---------------------------------------------------- Vlan ID : 2 Member Ports : Ex0/3, Ex0/4 Untagged Ports : None Forbidden Ports : None Name : Status : Permanent ----------------------------------------------------
SEFOS# show vlan Vlan database ------------- Vlan ID : 1 Member Ports : Ex0/1, Ex0/2, Ex0/3, Ex0/4, Ex0/5, Ex0/6 Ex0/7, Ex0/8, ... Untagged Ports : Ex0/1, Ex0/2, Ex0/3, Ex0/4, Ex0/5, Ex0/6 Ex0/7, Ex0/8, ... Forbidden Ports : None Name : Status : Permanent ---------------------------------------------------- Vlan ID : 2 Member Ports : Ex0/3 Untagged Ports : None Forbidden Ports : None Name : Status : Dynamic Gvrp ----------------------------------------
The switch propagates the VLAN declaration or registration on all of the forwarding ports in the switch. In the proceding example, when VLAN 2 was created on the nonroot bridge (switch 1), the switch propagated this information only on port Ex0/3 because port Ex0/4 is in the discarding state. Switch 2 learned about VLAN 2 through a single port (Ex0/3) using GVRP. Port Ex0/3 was added automatically to vlan2 on switch 1 because switch 2 propagated VLAN registration through port Ex0/3.
