Skip Navigation Links | |
Exit Print View | |
Sun Ethernet Fabric Operating System VLAN Administration Guide |
Configuring Static VLAN Entries
Retrieve the Configuration Details for all of the VLANs on a Switch
Retrieve the Configuration Details of a particular VLAN on the Switch
Configure a Static Unicast Entry
Configure a Static Multicast Entry
Configure Dynamic VLAN Learning
Configure Dynamic Multicast Learning
Configure Restricted VLAN Registration
Configure Restricted Group Registration
Configuring Service Classes and Expedited Traffic
Map a Priority to Traffic Class
Configure the Acceptable Frame Type
Configuring Static Unicast and Multicast Entries
Configure Static Unicast Entry in Topology 1
Configure VLANs on the Nonroot Bridge
For this procedure, you must first configure the VLAN. See Example Topolgy 2 for the topology for this procedure.
SEFOS# configure terminal SEFOS(config)# vlan 2 SEFOS(config-vlan)# ports extreme-ethernet 0/3,0/15,0/19 SEFOS(config-vlan)# exit SEFOS(config)# interface extreme-ethernet 0/15 SEFOS(config-if)# no shutdown SEFOS(config-if)# exit SEFOS(config)# interface extreme-ethernet 0/19 SEFOS(config-if)# no shutdown SEFOS(config-if)# exit SEFOS(config)# interface extreme-ethernet 0/3 SEFOS(config-if)# no shutdown SEFOS(config-if)# exit SEFOS(config)# exit
SEFOS# show mac-address-table Vlan Mac Address Type Ports --------------------------------------------------- 2 00:1b:21:53:6d:b9 Learnt Ex0/19 2 00:1b:21:53:6e:55 Static Ex0/15 2 01:02:03:04:05:06 Static Ex0/3 Total Mac Addresses Displayed: 3 ------------------------------------------------
SEFOS# show vlan id 2 Vlan database ------------------- Vlan ID : 2 Member Ports : Ex0/3, Ex0/15, Ex0/19 Untagged Ports : None Forbidden Ports : None Name : Status : Permanent ----------------------------------------------------
