Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System Uplink Port Trailing Administration Guide
Oracle Technology Network
Library
PDF
Print View
Feedback
search filter icon
search icon
Document Information
Using This Documentation
Sun Ethernet Fabric Operating System Uplink Port Trailing Protocol
Uplink Port Trailing Topology Example
Configure NEM24p-0
Configure NEM24p-1
Configure the ToR72
Verify the Configurations
Configure the Host
Verify the Uplink Port Trailing Feature
The following topology demonstrates the Uplink Port Trailing feature configured on access switches connecting to the servers. The example uses the Sun Blade 6000 Ethernet Switched NEM 24p 10GbE at the access layer. To enable this feature, the interfaces connecting from the access switch to the Sun Ethernet 10GbE Switch 72 (ToR72) and server-facing interfaces are bound together in a group.
image:Figure showing topology from Host 1 to Host 2 through TOR and redundant NEM switches
