Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System Uplink Port Trailing Administration Guide
Oracle Technology Network
Library
PDF
Print View
Feedback
search filter icon
search icon
Document Information
Using This Documentation
Sun Ethernet Fabric Operating System Uplink Port Trailing Protocol
Uplink Port Trailing Topology Example
Configure NEM24p-0
Configure NEM24p-1
Configure the ToR72
Verify the Configurations
Configure the Host
Verify the Uplink Port Trailing Feature
  1. Check the Uplink Port Trailing feature status.
    NEM24p-0 SEFOS# show uplink-trailing global
    % Uplink Trailing enabled
  2. Verify the configuration of all groups configured on this switch.
    NEM24p-0 SEFOS# show uplink-trailing group summary
    Uplink Trailing Group 10
    Description:     Uplink-trailing between NEM24p-0 & ToR72p-1
            Admin Status:            Enabled
            Status:                  Up
    Port             Type   Status
    Ex0/1        uplink      Up
    Ex0/18       downlink    Up
    NEM24p-0 SEFOS# show uplink-trailing group detail
            Status:                  Up
    Link State Change: Up   1       Down    0
    Port             Type   Status
    Ex0/1        uplink      Up
    Ex0/18       downlink    Up
  3. Verify the configuration of a particular group.
    NEM24p-0 SEFOS# show uplink-trailing group 10
            Status:                  Up
    Port             Type   Status
    Ex0/1        uplink      Up
    Ex0/18       downlink    Up
    NEM24p-1 SEFOS# show uplink-trailing group 20
    Uplink Trailing Group 20
    Description:     Uplink-trailing between NEM24p-1 & ToR72p-1
            Status:                  Up
    Port             Type   Status
    Ex0/1        uplink      Up
    Ex0/18       downlink    Up
  4. Verify the Uplink Port trailing configuration on an interface.
    NEM24p-0 SEFOS# show uplink-trailing interface extreme-ethernet 0/1 summary
    Interface Ex0/1
    Port Type                uplink
    Port Link Status         Up
    NEM24p-0 SEFOS# show uplink-trailing interface extreme-ethernet 0/1 detail
    Interface Ex0/1
    Group Description:       Uplink-trailing between NEM24p-0 & ToR72p-1
    Group Admin Status:      Enabled
    Group Link Status:       Up
    Port Type                uplink
    Port Link Status         Up
    NEM24p-0 SEFOS#
    NEM24p-0 SEFOS# show uplink-trailing interface extreme-ethernet 0/18 detail
    Interface Ex0/18
    Port Type                downlink
    Port Link Status         Up
