Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System Uplink Port Trailing Administration Guide
Oracle Technology Network
Library
PDF
Print View
Feedback
search filter icon
search icon
Document Information
Using This Documentation
Sun Ethernet Fabric Operating System Uplink Port Trailing Protocol
Uplink Port Trailing Topology Example
Configure NEM24p-0
Configure NEM24p-1
Configure the ToR72
Verify the Configurations
Configure the Host
Verify the Uplink Port Trailing Feature
Configure NEM24p-1
  1. Start the configuration with all ports and the default VLAN shut down.
    Also, enable the Uplink port trailing feature.
    Tip  - It is a best practice to start the configuration with all the ports and default VLAN shut down. Disable GVRP and GMRP, because dynamic VLAN learning is not suggested.
    NEM24p-1 SEFOS# configure terminal
    NEM24p-1 SEFOS(config)# set gvrp disable
    NEM24p-1 SEFOS(config)# set gmrp disable
    NEM24p-1 SEFOS(config)# set port-channel enable
    NEM24p-1 SEFOS(config)# set uplink-trailing enable
    % Enabling Uplink Trailing Module
    NEM24p-1 SEFOS(config)# interface vlan 1
    NEM24p-1 SEFOS(config-if)# shutdown
    NEM24p-1 SEFOS(config-if)# no ip address
    NEM24p-1 SEFOS(config-if)# exit
    NEM24p-1 SEFOS(config)# interface range extreme-ethernet 0/1-24
    NEM24p-1 SEFOS(config-if-range)# shutdown
    NEM24p-1 SEFOS(config-if-range)# end
  2. Create and enable port-channel between switches according to the topology.
    NEM24p-1 SEFOS(config)# interface port-channel 13
    NEM24p-1 SEFOS(config-if)# no shutdown
    NEM24p-1 SEFOS(config)# end
  3. Configure VLANs manually.
    You must add at least one port to the VLAN before you can assign the VLAN a name.
    NEM24p-1 SEFOS(config)# vlan 300
    NEM24p-1 SEFOS(config-vlan)# ports add port-channel 13 name vlan-1
    NEM24p-1 SEFOS(config-vlan)# vlan active
    NEM24p-1 SEFOS(config-vlan)# exit
    NEM24p-1 SEFOS(config)# vlan 301
    NEM24p-1 SEFOS(config-vlan)# ports add port-channel 13 name vlan-2
  4. Create a uplink trailing group.
    The group number can be 1 to 65355.
    NEM24p-1 SEFOS(config)# uplink-trailing 20
    %  Uplink Trailing Group 20 Created
    NEM24p-1 SEFOS(config-ultr)# description "Uplink-trailing between NEM24p-1 & ToR72p -1"
    NEM24p-1 SEFOS(config-ultr)# end
  5. Configure the port-channel to allow all VLANs.
    NEM24p-1 SEFOS(config-if)# switchport mode trunk
  6. Enable the ports and add them to the appropriate port-channels.
    Assign the ports to the uplink-trailing group as uplink or downlink to bind them together
    NEM24p-1 SEFOS(config-if-range)# description "connected to ToR72p-1"
    NEM24p-1 SEFOS(config-if-range)# channel-group 13 mode active
    NEM24p-1 SEFOS(config-if-range)# uplink-trailing group 20 uplink
    NEM24p-1 SEFOS(config-if-range)# no shutdown
    NEM24p-1 SEFOS(config-if-range)# exit
    NEM24p-1 SEFOS(config)# interface extreme-ethernet 0/18
    NEM24p-1 SEFOS(config-if)# description "connected to Linux blade, Host-2"
    NEM24p-1 SEFOS(config-if)# uplink-trailing group 20 downlink
  7. Save the configuration.
    NEM24p-1 SEFOS# copy run start
    Building configuration ...
    [OK]
