| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System LLDP Administration Guide |
Configure the LLDP System Control Status
Configure the LLDP Module Status
Enabling a Specific Management Address
Enable an Existing IP Interface
Enable IEEE 802.1 Organizationally-Specific TLVs
Enabling a Particular VLAN Name
Enable IEEE 802.3 Organizationally-Specific TLVs
Disable LLDP Basic Optional TLVs
Disable IEEE 802.1 Organizationally-Specific TLVs
Disable the IEEE 802.3 Organizationally-Specific TLVs
Configure the LLDP Chassis-ID Subtype
Configure the LLDP Port-ID Subtype
Enable the LLDP Notification Status or Type
By default, the LLDP admin status is set to transmit and receive (TxAndRx). You can change the LLDP admin status to change LLDP operational mode to any of the following values:
TxAndRx - Transmit and receive (default)
TxOnly - Transmit only
RxOnly - Receive only
Disabled
SEFOS# show lldp interface Ex0/1: Tx State : Enabled Rx State : Enabled ...
SEFOS# configure terminal SEFOS(config)# interface extreme-ethernet 0/1 SEFOS(config-if)# no lldp receive SEFOS(config-if)# exit SEFOS(config)# end
SEFOS# show lldp interface extreme-ethernet 0/1 Ex0/1: Tx State : Enabled Rx State : Disabled ...
SEFOS# configure terminal SEFOS(config)# interface extreme-ethernet 0/1 SEFOS(config-if)# no lldp transmit SEFOS(config-if)# exit SEFOS(config)# end
SEFOS# show lldp interface extreme-ethernet 0/1 Ex0/1: Tx State : Disabled Rx State : Enabled ...
SEFOS# configure terminal SEFOS(config)# interface extreme-ethernet 0/1 SEFOS(config-if)# no lldp transmit SEFOS(config-if)# no lldp receive SEFOS(config-if)# exit SEFOS(config)# end
SEFOS# show lldp interface extreme-ethernet 0/1 Ex0/1: Tx State : Disabled Rx State : Disabled ...
