| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System LLDP Administration Guide |
Configure the LLDP System Control Status
Configure the LLDP Module Status
Configure the LLDP Admin Status
Enabling a Specific Management Address
Enable an Existing IP Interface
Enabling a Particular VLAN Name
Enable IEEE 802.3 Organizationally-Specific TLVs
Disable LLDP Basic Optional TLVs
Disable IEEE 802.1 Organizationally-Specific TLVs
Disable the IEEE 802.3 Organizationally-Specific TLVs
Configure the LLDP Chassis-ID Subtype
Configure the LLDP Port-ID Subtype
Enable the LLDP Notification Status or Type
This section describes how to configure IEEE 802.1 organizationally-specific TLVs for transmission when the transmission status is set to disabled by default.
Port VLAN ID
Port and protocol VLAN ID
VLAN name
SEFOS# configure terminal SEFOS(config)# vlan 1 SEFOS(config-vlan)# ports extreme-ethernet 0/1 name vlan1 SEFOS(config-vlan)# end
SEFOS# configure terminal SEFOS(config)# interface extreme-ethernet 0/1 SEFOS(config-if)# lldp tlv-select dot1tlv port-vlan-id protocol-vlan-id all vlan-name all SEFOS(config)# end
SEFOS# show lldp local extreme-ethernet 0/1 Port Id SubType : Interface Alias Port Id : Ex0/1 Port Description : Ethernet Interface Enabled Tx Tlvs : Port Vlan ...
When the switch comes up, no protocol group is initially mapped to VLAN, so no entry is present in the VLAN module for the PPVID. A port and protocol VLAN entry is created in LLDP with the protocol VLAN ID value of 0, and the entry is transmitted after you enable PPVID TLV transmission.
SEFOS# show lldp neighbors extreme-ethernet 0/1 detail ... Extended 802.1 TLV Info -Port VLAN Id : 1 -Port & Protocol VLAN Id Protocol Vlan Id Support Status ---------------- ------- ------ 0 Supported Enabled -Vlan Name Vlan Id Vlan Name ------- --------- 1 vlan1 ------------------------------------------------------------ Total Entries Displayed : 1
