| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System LLDP Administration Guide |
Configure the LLDP System Control Status
Configure the LLDP Module Status
Configure the LLDP Admin Status
Enabling a Specific Management Address
Enable an Existing IP Interface
Enable IEEE 802.1 Organizationally-Specific TLVs
Enabling a Particular VLAN Name
Enable IEEE 802.3 Organizationally-Specific TLVs
Disable LLDP Basic Optional TLVs
Disable IEEE 802.1 Organizationally-Specific TLVs
Disable the IEEE 802.3 Organizationally-Specific TLVs
Configure the LLDP Chassis-ID Subtype
Configure the LLDP Port-ID Subtype
Enable the LLDP Notification Status or Type
The following list contains explanations of the errors:
Memory allocation failures - The number of times that memory allocation failed in LLDP.
Queue overflows - The number of times the input queue overflowed in LLDP.
Table overflows - The number of times remote-table overflows occurred in LLDP (the number of times a remote table has dropped the newly learned neighbor entry because of insufficient space in a remote system table).
