| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System LLDP Administration Guide |
Configure the LLDP System Control Status
Configure the LLDP Module Status
Configure the LLDP Admin Status
Enabling a Specific Management Address
Enable an Existing IP Interface
Enable IEEE 802.1 Organizationally-Specific TLVs
Enabling a Particular VLAN Name
Enable IEEE 802.3 Organizationally-Specific TLVs
Disable IEEE 802.1 Organizationally-Specific TLVs
Disable the IEEE 802.3 Organizationally-Specific TLVs
Configure the LLDP Chassis-ID Subtype
Configure the LLDP Port-ID Subtype
Enable the LLDP Notification Status or Type
SEFOS# configure terminal SEFOS(config)# vlan 1 SEFOS(config-vlan)# ports extreme-ethernet 0/1 name vlan 1 SEFOS(config-vlan)# end
SEFOS# configure terminal SEFOS(config)# interface extreme-ethernet 0/1 SEFOS(config-if)# no lldp tlv-select basic-tlv port-descr sys-name sys-descr sys-capab mgmt-addr all SEFOS(config)# end
SEFOS# show lldp local extreme-ethernet 0/1 ... Enabled Tx Tlvs : Port Vlan, Mac Phy, Link Aggregation, ...
The enabled TLVs do not display any basic optional TLVs because basic they are disabled.
SEFOS# show lldp neighbors extreme-ethernet 0/1 detail ... Port Description : Not Advertised System Name : Not Advertised System Desc : Not Advertised Local Intf : Ex0/1 Time Remaining : 104 Seconds System Capabilities Tlv : Not Advertised Management Address : Not Advertised ...
