| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System LLDP Administration Guide |
Configure the LLDP System Control Status
Configure the LLDP Module Status
Configure the LLDP Admin Status
Enabling a Specific Management Address
Enable an Existing IP Interface
Enable IEEE 802.1 Organizationally-Specific TLVs
Enabling a Particular VLAN Name
Enable IEEE 802.3 Organizationally-Specific TLVs
Disable LLDP Basic Optional TLVs
Disable IEEE 802.1 Organizationally-Specific TLVs
Disable the IEEE 802.3 Organizationally-Specific TLVs
Configure the LLDP Chassis-ID Subtype
Configure the LLDP Port-ID Subtype
Enable the LLDP Notification Status or Type
If a new IP address is configured for the system, then the address is not transmitted by default (that is, the TLV transmission status of the newly configured IP address is disabled).
SEFOS# configure terminal SEFOS(config)# vlan 2 SEFOS(config-vlan)# ports extreme-ethernet 0/1 SEFOS(config-vlan)# end SEFOS# configure terminal SEFOS(config)# interface vlan 2 SEFOS(config-if)# ip address 15.0.0.1 255.255.255.0 SEFOS(config-if)# no shutdown SEFOS(config-if)# end
SEFOS# show lldp local mgmt-addr Management Address TxEnabledPorts ------------------ -------------- 12.0.0.1 Ex0/1 15.0.0.1
The TxEnabledPorts for management address 15.0.0.1 do not display any interfaces.
SEFOS# configure terminal SEFOS(config)# interface extreme-ethernet 0/1 SEFOS(config-if)# lldp tlv-select basic-tlv mgmt-addr ipv4 15.0.0.1 SEFOS(config)# end
SEFOS# show lldp local mgmt-addr Management Address TxEnabledPorts ------------------ -------------- 12.0.0.1 Ex0/1 15.0.0.1 Ex0/1
SEFOS# show lldp neighbors extreme-ethernet 0/1 detail ... IfId SubType Address OID ---- ------- ------- --- 1009 IPv4 12.0.0.1 1 3 6 1 2 1 2 2 1 1 1010 IPv4 15.0.0.1 1 3 6 1 2 1 2 2 1 1 ...
