Configuring the SLB Topology Example
SLB Configuration Guidelines and Prerequisites
Configuring the SLB-L2 Topology Example
Sample SLB-L2 Topology Example
SLB-L2 Configuration Guidelines and Prerequisites
Conditions for a Member Participating in Load Distribution
Set the Traffic Distribution Policy
Restore the Default Traffic Distribution Policy
View the Traffic Distribution Policy
Restore the Default Failover Method
Creating Example SLB Configurations
Creating a Basic SLB Configuration
Save the Current Configuration
Creating a Separate VLAN SLB Configuration
Configuration With Separate VLANs Steps
Creating a Multiple SLB Group Configuration
Multiple-SLB-Group Configuration
Configuration With Multiple SLB Groups Steps
Set Up the Servers in SLB Group 1
Set Up the Servers in SLB Group 2
Restart the Server Following Failure
Creating SLB-L2 Configuration Examples
Bump-In-The-Wire Configuration
Creating a Single-Switch Configuration
Basic Single-Switch Configuration
Create a Single-Switch Configuration
Creating a Dual-Switch Configuration
Create a Dual-Switch Configuration
These sections describe how to configure SLB entries using the configurations presented in SLB Topology Example. These examples were produced on a system running the Oracle Solaris OS.
Before configuring SLB, ensure that the SLB Configuration Guidelines and Prerequisites are satisfied.
