Configuring the SLB Topology Example
SLB Configuration Guidelines and Prerequisites
Configuring the SLB-L2 Topology Example
Sample SLB-L2 Topology Example
SLB-L2 Configuration Guidelines and Prerequisites
Conditions for a Member Participating in Load Distribution
Set the Traffic Distribution Policy
Restore the Default Traffic Distribution Policy
View the Traffic Distribution Policy
Restore the Default Failover Method
Creating Example SLB Configurations
Creating a Basic SLB Configuration
Save the Current Configuration
Creating a Separate VLAN SLB Configuration
Configuration With Separate VLANs Steps
Creating a Multiple SLB Group Configuration
Multiple-SLB-Group Configuration
Configuration With Multiple SLB Groups Steps
Set Up the Servers in SLB Group 1
Set Up the Servers in SLB Group 2
Restart the Server Following Failure
Creating SLB-L2 Configuration Examples
Bump-In-The-Wire Configuration
Creating a Single-Switch Configuration
Basic Single-Switch Configuration
Create a Single-Switch Configuration
Creating a Dual-Switch Configuration
Create a Dual-Switch Configuration
You can simulate a link failure by shutting down one of the switch ports. This example shuts down port 16.
SEFOS# configure terminal SEFOS(config)# interface extreme-ethernet 0/16 SEFOS(config-if)# shutdown SEFOS(config-if)# end
SEFOS# show slb l2 L2 SLB Group #1 Failover Method: Failover to All ports Members: Port State Comments ==== ===== ================= 15 ACTIVE 16 FAILED Failover to All ports 17 ACTIVE 18 ACTIVE
This shows that port 16 has failed. Its state changed from active to failed. The traffic hashed to the server for port 16 will be rehashed to all remaining active ports.
